Question about Kenmore 24 in. 16534 Built-in Dishwasher
The cover of detergent dispenser does not open..
Our Kenmore 15254 6 months old, the cover of detergent dispenser does not open and detergent tabs stay's in the cup. What can it be? Thank you.
same problem with the cover not opening and the detergent still in the cup. the problem is intermitent, but happens too frequently, please help.
  • jctrane Sep 16, 2008
    We use the powder type detergent in our 2 year old Kenmore dishwasher. VERY frequently (perhaps one third of the time) we find that, after running the washer cycle, the recepticle (for the powder) is clogged with the damp detergent that is caked up, even tho' the recepticle 'door' itself is open after the cycle has run.. We have tried reducing the amount of powder (which seems to help occasionally). Is there a better fix for this problem?
  • shannonpas Oct 10, 2008
    We use the tabs but the door doesn't open at all. We have to put our dishes through the wash 2 or 3 times before the dang thing releases the detergent. Any suggestions other than try a different detergent?
    President:
  • Kenmore Master
  • 2,651 Answers
Switch back to using powdered soap, sometimes what happens is hte tablets your using are actually to big for the dispensor door and too much pressure is put againt the actual door so when its triggered to open there too much resistance nad cannot open, sounds silly bu have actually sen it in action. and liquid detergent tends to clog or gunk up hte door spring assy, powdershte best detergent to use for d/w's
Posted on Mar 20, 2008
Kenmore front load washing machine leaking water from under the the detergent dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub. Pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer and remove it. Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening. Reach down into this opening to see if an item is inside the hose. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again. If the dispenser still leaks, then I recommend calling a service technician to diagnose and fix this problem.
May 01, 2012 | Kenmore Washing Machines
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Rough film on dishes
first clean dw use tang then prime sink and run dw after that cut back on detergant
Jun 06, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 48102 Front load washer won't siphon out laundry detergent.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore Energy Star 44092 Front Load...
Water over flowing from the detergent dispensers
Jun 18, 2009 | Kenmore HE2 Plus Front Load Washer
Detergent dispenser clogged-Kenmore 90 series washer
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 16, 2009 | Kenmore 24902 Top Load Washer
Kenmore 11047511701 Front Load clothes washer: Liquid detergent runs out of dispenser and down front of machine immediately as liquid is poured in instead of holding liquid. Dispenser was not overfilled.
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Detergent Fill Dispenser
It may be gummed up inside with old detergent that has caked on . Try rinsing out the despencer until it opens and closes easy. DFD
Apr 22, 2009 | Dishwashers
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
It is most likely the flip spring...you need to be certain that the legs of the spring are inside the door edge and the spring does not swing freely...and there must be tension on the spring so that when the latch releases the door flips...you can also try this with an elastic, put the elastic inside the closed door and up around the drying solution knob, this will let the door flip open showing that the latch does work
Nov 11, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 24 in. 16534 Built-in Dishwasher Logo
274 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
