Question about Maytag Neptune MAH5500B Front Load Washer
My washer will not run a full cycle. When I went to put the load in the dryer the clothes were still soaked. I tried to run a spin cycle. It takes 9mins. It seems to start the cycle when the time reaches 7 min the timer goes to 0 then the machine beeps like the cycle is done.
  • 1 more comment
  • kaz9497 Mar 20, 2008
    The door light does come on and the door does lock. We have never had any work done on the washer and it is about 8 years old.
  • Anonymous Mar 21, 2008
    I have thye same issue. Clothes are soaked when the cycle is done. I also get an "od" on the display, although I don't know what this means. If I put is on spin only, it sounds like it's going, shows 7 min remaining and then goes to 0.
  • Ron Coons
    Ron Coons May 11, 2010
    when in cycle,is hte door lock light going on????and if so is the door actually locking???have you ever had any work done to it and whats the approx age???
    President:
  • Maytag Master
  • 2,651 Answers
Only 2 or 3 real problems with this machine, bad machine controller( behind console) although lights on are sign that its good,
Either the pump is clogged and not draining water so it will never spin let alone spin full speed with water in tub, i also doubt that because it seems that s there just water within the clothes and not a tank full of water,
which leaves the last Major issue with machine and that's the motor controller, not telling the motor to spin.. could also be a bad motor but i really doubt that all....
This is a funny machine because depending on when it was made (serail number denotes its age) im looking up the model and your manual states that you have a 3rd yr to 10 yr part warr on the motor, Well on earlier models you cant replace the motor itself it comes as part of a kit, "NEPTUNE REPAIR KIT" which also includes the motor control board. reason i mention that is I"m able to get a motor controller covered by warr(as an authorized maytag technician) if the model will take the neptune repair kit, sure youll need to pay service and labor but the a part would be covered.
Posted on Mar 20, 2008
Washer wont go through the cycles... it stops working before the final rinse cycle
MAH5500B Maytag Neptune washer stops and I have to put back into star and not just wash one side wet clothes and Susie sige water drains can only hear a buzz and it takes many items and each shaved marked "nf" and "Lf"
May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes are soaking wet after done
You may need a belt or a pump. Call sears they will help more.
Oct 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune frot load will not reach full spin speed.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer spin cycle
Hi joystoy
I would start with the belt. it sounds like the belt is going and that is the least expensive to fix. try that, if that doesnt work then i would call a repair company to look at it.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
189 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
