Sound drivers in/op
I installed a EIDE hard drive 320GB then ran my restore disk well i cant seem to get my sound drivers back!!! I have a logitech x-230 is there a way to down load any other sound drivers from a free sight????? HELP PLEASE!!!
    Scholar:
  • 105 Answers
The logitech speakers are plug and play and should need no drivers. Here is the web page: I suspect you need the drivers for your sound card or for integrated audio.
Posted on Mar 20, 2008
I cant download op cd
If the new hard disk is a SATA hard disl then the problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 18, 2012 | Computers & Internet
Ihave a sagate 320 inturnal HD that was installed on my desktop Comp. 1.5 years ago I am getting window massage to download all my data due to the HD failing. I am looking at the date code and it appears...
It sounds as if the SMART measurements on your Seagate 320GB hard drive are triggering the Windows message advising that the drive is failing.
You would be best advised to backup your data from this drive to a different drive or on to DVD media (depending on how much data is involved).
To test the failing Seagate disk, download a copy of Hiren's Boot CD which is a CD image file (.ISO) and must be burnt to a blank CD disc - then boot the computer with the failing disk from this CD - then select DOS Programs on the initial menu, then choose Hard Disk Tools and then HDAT2 - this is a tool which will let you try to recover any bad sectors on your boot disk.
On the Hard Disk Tools menu there is also a SMARTUDM - HDD S.M.A.R.T. viewer which will let you examine exactly which areas of the Seagate disk are giving the problem leading to the failure message.
Jan 08, 2012 | Seagate Barracuda 7200.10 ST3160815A -...
I cannot install my logitechcam version 10.0a
can you please tell me the error message if you get any?
And before continuing, please check for if your OP is up to date (Start, Windows Update>enter> click on icon>Check for updates) if your OP is windows, if not please tell me what is your OP. If you get updates, install them, restart PC, try installing your cam from the CD.
Come back soon for instructions or to tell if it worked.
Jun 20, 2011 | Logitech QuickCam Communicate STX Webcam
Computer stopped midway during a restore point and now cannot be restored or backed up or transfer files. Nothing is being recognized by the system. The restore disc is not being recognized by the drive...
reformat the hard drive and try to re-install the disk.. you hard drive it too full and cannot load temporary files that need to extract to install components and op sys. format the hard drive.
please rate this post.. thanks.
Dec 01, 2010 | Gateway 505GR PC Desktop
I bought a third party ie seagate 160 gb sata hard disk and replaced in my laptop but windows installation disk did not find any hard disk present in the computer. how to install a third party hard disk ?
If you are installing Windows XP on a SATA hard drive, Windows installation CD does not have a SATA driver, that is why it does not detect the hard drive. please click on this link and follow my instruction to install Windows on a SATA hard drive :-
Oct 31, 2010 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Setup did not find any hard disk drivers installed on your...
dear friend
you need to goto bios and search for and option "sata native support"
set it to disabled
if you cant find that , then you need to splitstream sata drivers into windows xp cd, if this is the case please ask me to tell you the method
thanks
Apr 10, 2009 | Toshiba Satellite M205-S7452 Notebook
Can't write onto HDD
This seems like a driver confliction. i suggest you re install the driver sets that came with this unit. it should be a disk that came with the HDD. Use this disk and reinstall all software. this should fix this issue. I would also defrag the main on board hard drive as well. Sometimes, this simple tool will fix this issue as well.
Feb 19, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Windows XP SP2, Intel DG965WH mobo. Two SATA hard drives, two EIDE hard drives (WD200EB). Suddenly one day, without warning, the two EIDE drives just disappeared from the Hard Disk Drive list and files...
the problem sounds like you either lost the IDE channels on the MOBO or the chipset was updated with corrupt files.
run everest home and see if there are current updates for the northbridge chipset. if you have 2 ide channels on the board switch the primary and secondary ribbons and see if the hard drives are there. if your cdrom's are ide and after switching ribbon cables they disappear and the hard drives reappear your mobo lost an ide channel, you would need to replace the board.
Aug 01, 2008 | Computers & Internet
Need to install OEM Windows 98
ok you need to reboot your computer from the CD rom with xp disk in it.
start your computer hold down the f12 key, a small menu will come up , pick cd/dvd/cd-rw drive with your arrow keys ,
select enter , follow xp directions on how install operating system on the monitor.
Jan 15, 2008 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
60 people viewed this question
 Grubhead
Grubhead
