Question about Acer Aspire 3000 Notebook
Completely dead My Acer 3000 was working perfectly for years and then all of sudden it is dead. No lights in front, no power up, no sign of life. I put a volt meter on the power supply and it is showing 18 volts. Is this a major problem with these laptops?
    Problem Solver:
  • 5 Answers
Check the power adapter connection or the socket. Recently my power adapter socket gave me the same problem. When I check from the adapter using voltmeter it's seems to be working.
But when i plugged it in the laptop, nothing happens. So I google around for help and found this tutorial after following the suggestions I managed to revive my notebook.
Posted on Mar 20, 2008
SOURCE:
Acer Aspire ,5535 black screen,on/off button ok,...insert dvd searching??power light on, batt charging light on,fan on..where to go next
ok, 10 year old laptop
step1 , as always remove the old dead shorted huge battery first.
run now? it will on AC for every if you want.
Led Glowing tell not much its just and LED, so dont look at them if on, unless and LED blinks codes. ok?
what matters is power, power is first. no power no joy, ever.
so out the battery now.
Put in a new RTC coin cell battery next 7 year life rated you are 3 years past that at 10 years old, (end of useful life that)
next is fans, , ok fan is on.
next is what, TEXT got TEXT ON SCREEN>? ANY THING??
I guess ZERO SCREEN anything of any kind>.
we next use a flash light, this PC has crummy , CCFL back lamp tubes that when dead screen goes, dead, as most have this old.
only few never used laptops last 10 years old.
so with the flash light (dark room) at an angle shin the LCD
see data, now on the screen, yes, that is a DEAD CCLF.
on ebay you see them selling new CCLF screens for this PC.
my bet the CCFL are dead. as most are this old.
All laps this old fail in this order,
BIG battery goes bad or shorts.
COIN cell dead.
CCLF dead ( ended about year 2010 , LED back lamps began)
HDD dead at 5 to 10 years old.
this is all Expected. all from carbon14 dating a PC, I can say that.
yours is 2008 made.
Aug 17, 2018 | Acer Computers & Internet
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
Why has my Nokia 800 suddenly gone dead?
try holding the power key for over 10 secs. this simulates a "battery pull". try restarting after that. im assuming you are not out of juice and have tried some stuff there already.
Jul 20, 2014 | Nokia Lumia 800
Laptop Acer Aspire 3354-1096 Power-up Problem
Do you have access to a multimeter to track the AC/DV current? If the power is getting to the laptop, correct DC/AMP voltage? AC jack been damaged, pulled, yanked...etc? Hard to say which component without checking with a multimeter? PSU?
Nov 25, 2012 | Computers & Internet
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
Acer 4520 Dead, Blank screen , No response...
It sounds like something on the motherboard has possibly shorted out. That can range from the CPU to RAM to the DVD. If it's still under warranty I would suggest sending it in for repair.
If you do send it in, please let them know to backup your harddrive if they have to reformat and restore it for any reason. Your important files are still there and safe.
Nov 24, 2009 | Acer Aspire 4520-5582 Notebook
My battery dies within 20 minutes of use. I've let my battery charge overnight but i still only get about 20 to 30 min of life out of it. is that standard for an Acer Aspire 3000?
If the battery is more than one year old, or has been often used with the power supply plugged in, it might have degraded.
Sometimes you can regenerate it to some lesser extent by completely draining it and recharging overnight (but that's apparently what you already did).
So I'm afraid you will have to replace it.
A new Acer battery (4400 mAh) should get you at least three hours life, and up to six hours by being real careful (lowest screen luminosity, no disk activity, no heavy usage: e.g., vanilla word processing)
Oct 22, 2009 | Acer Aspire 3000 Notebook
All of a sudden" going into hibernation"
try to open ur laptop cover .
on the mainboard there is usually a jumper located near the cmos battery. try to change its position for 3 seconds and return it back to its normal position.
this way u will clear the board memory .
start ur computer and load default settings.
hope this will help.
May 14, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
113 people viewed this question
Ekse
Alun Cox
