Question about Mitsubishi WD-52628 52" Projection HDTV
Techman: Guru
Kept me on line for approx. 20 min. All he posted was Hello There. Did not respond to problem.
  • Mitsubishi Master
  • 8,617 Answers
Whats the nature of your problem? I will try and help you I live and breath mitsubishi DLPs so tell me the symptoms of what its doing?
Posted on Mar 20, 2008
I need instruction sheets for exchanging screen and clavier in German ASPIRE5315 , ICL50 ,screen 33x21cm
hello
type into google search box
how to replace aspire 5315 screen.
you can watch video and change screen in approx 15 to 20 mins
john
Jul 10, 2011 | Aspire Acer AS5315-2856 Laptop
Machine runs fine for approx 20 mins. Thereafter when drive is engaged will run for 20 seconds before engine starts to die .If drive is disengaged engine will idle fine until drive is engaged and problem...
your engine is starving for fuel supply. Remove fuel line from carburator. If fuel flows from line remove carburator and clear obstruction from needle valve and insure that fuel is not being restricted. If fuel flow is slow: clean and rebuild if necessary the fuel pump (if applicable) or follow fuel line to fuel tank and remove blockage: in line fuel filter fuel, tank strainer, or on and off valve that may be choked off.
Mar 02, 2011 | Mantis 4-Cycle Tiller
What is the drive cycle for a 2004 Caravan after a sensor has been replaced?
Hello! The Drive-Cycle is as follows...Check engine light off, codes cleared; cold start...Warm up engine 5 minutes...Drive (w/ steady throttle) at a steady speed between 40 and 60 mph for 8 min...Stop and idle 3 min...Drive (w/ steady throttle) at a speed above 20 mph for 2 minutes...Turn key off, leave off 10 min...
Guru.............Saailer
Feb 07, 2011 | 2004 Dodge Caravan
I have a 4 liter V6 2003 Ford Explorer ( 2 door). The check engine came on and then it started idling rough. When it idles rough the AC blows hot. Recently it has started stalling when idling at a...
Hello! Most probable cause is a leak in the vacuum line or broken elbow connection to the Positive Crankcase Ventilation (PCV) valve...Check PCV and its vacuum line...Send results...
Guru..............saailer
Aug 27, 2010 | 2003 Ford Explorer
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
How can I unlock the TV?
Try pressing the "F" or function button and hold while pressing the Mute or "M" button at the same time. Good Luck
Sep 07, 2006 | Apex Digital AT2002S 20" TV
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Mitsubishi WD-52628 52" Projection HDTV Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
