Question about Sony VAIO VGN-N130G/W Notebook
Ram upgrade I recently purchased (2) 1GB STICK OF RAM. Since install my machine flashes a blue screen with a bunch of text and then restarts. I tried a set of recovery disks to restore system and on install it kept flashing corrupt file and would restart intermittently. Please Help before I turn this thing into a Frisbee. Thanks Ryan
    Genius:
  • 1,027 Answers
Initial blue screen of death is probably caused by the ram.
install original ram and see if everything is ok, next install 1 of your upgrade sticks, reboot and see what happens, if it fails use the other stick, if it still fails, sell those on e-bay and run a scan from crucial.com and see what is compatible.
Posted on Mar 20, 2008
I have an eMachine desktop/tower 3230. I need bios upgrade for extra Ram ...
Hello visit emachine here:
http://support.gateway.com/us/en/emac/default.aspx
And select your pc model by number.
Remember to select the right model, because flashing the bios with a wrong one will destroy the mainboard.
I have newer heard that a bios upgrade was necessary to upgrade the ram.
Some mainboards do have a limit of 2gb ram, and the bios upgrade does nothing to that.
Try to clean the pc out for dust, and renew the the cooling paste between the cpu and the cooling element.
One of the ram modules could have a defect.
Try to test one module at the time.
If you get the blue screen of death, the problem is elsewhere like power supply, or harddrive.
Good luck
Jan 17, 2013 | MSI 6714 i845GL Chipset 400/533FSB...
AOD270-1824 can i put a 4gb ram in it
You can add 1GB of ram but that's it. Definately not a 2GB Stick or 4GB stick.
Sep 01, 2012 | Acer Espresso Black 10.1" AOD270-1824...
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
Toshiba Satellite Notebook M45-S351 I recently purchased an upgraded hard drive - 160 GB Samsung Spinpoint and upgraded the RAM (Crucial 1 GB, bringing the total to 1.5 GB of the allowable 2 GB). Impetus...
Remove thwe new RAM and hard drive. Does it boot to the BIOS menu? If yes, add the hard drive and do the same again then add RAM and do the same.
I suspect something does not fit in properly. Probably the RAM.
Don't forget to initialise the hard drive if trying to format it. The System disk should take care of that.
Dec 21, 2010 | Toshiba Satellite M45-S351 Notebook
Upgrading memory to 4GB failure
try to see if that memory is supported with your motherboard. The memory has something to do with that problem.
Jun 16, 2009 | Acer Extensa 5620 Notebook PC
Ibm netvista 6794 ram upgrade problems
CL- pc13 memory is reccomended. 512k memory sticks of the pc133 variety give a lot of users problems, you have to find a specific type of memory when installing 512k chips. to get all 3 to work, i sugfgest using 3 sticks of the exact same type (same memory modules on each stick)
Dec 27, 2008 | Computers & Internet
Ram upgrade problems IBM netvista 6794
You can try this site, it scans your system to see if your computer can run more memory than what is currently installed. it helps you find the right memory modules for your system and and an option for you to read reviews if available and if you want to buy it.
try this site: www.crucial.com
Please rate this solution
Dec 26, 2008 | IBM NetVista PC Desktop
Blue Screen
OK, so I took out the added RAM, changed the internal RAM to a new 1GB stick. The machine booted, windows started, I logged on, then blue screen. I put the old internal RAM back in, changed the hard drive, same result. This test suggests that the RAM is fine as is the hard drive as the blue screen appeared with different hardware. My next step is to replace the motherboard as the appears to be the issue. I'll let you know how I get on.
Jul 17, 2008 | Toshiba Computers & Internet
Sony VAIO VGN-N130G/W Notebook Logo
54 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
