The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple. I hope this helps.
Thank you for this comment. It really works. Thank you. =D
thank you very ..............................................................................................
[email protected]
I'"m verry happy, it was so simple, thank you verry much
thnx man. you saved the day...
love it thanks so easy
Touch pad stopped working. daughter age 5 got hold of laptop
Unplug any external mouse and uninstall software for the touchpad, if this does not work, then it needs to be replaced.
SOURCE: in my acer emachine e725,
You need touchpad drivers to make it work. Please download the driver for windows XP from http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Acer-Aspire-5600-Touchpad-Driver.shtml
or if you are using any other windows let me know
SOURCE: XP DRIVERS for the ACER EMACHINES E725-4122 DC
You can download from following link:
http://support.emachines.com/em/driver/nb/e725.html
Thanks
SOURCE: Emachines e725 Touchpad Not Working
Most laptops are setup to turn off the touch pad when a mouse is plugged in. If you plugged it in because the touch pad stopped working, you most likely have a bad driver or touch pad has gone bad. Go to your manufactures web site and down load the latest driver and reinstall the driver. If this doesn't fix it your touch pad is most likely gone bad. However, if your not running an anti-virus there's a chance you've picked up on a virus or some malware.
Testimonial: "Great Advice .. Really Helpful !!"
SOURCE: i have a emachines e725 dose it have a webcam
Yes it has a incorporated webcam. The resolution of the webcam is 0.3 mp. Go to the Acer website and check to convince yourself.
If you need further assistance please post.
Hello, press Ctrl + F7 and this should enable back your touch pad. I think it was disabled and that's why it did not work. If this does not solve the problem, then I'm afraid your touch pad as developed a fault and you will be needing the assistance of a repairer. Take care.
