Question about Hotpoint RB787 Electric Kitchen Range
GE Profile range oven door
The glass door fell off. It looks like it was held togather for glue. Now the oven door does not stay open when it is open all the way down. If I glue the door back on, would the door stays open? What glue do I use?
Help!
  • 2 more comments
  • jtlgol Mar 20, 2008
    it's 183D5580P158
    I mean JGB900
  • jtlgol Mar 21, 2008
    The glass fell off from that metal strip. So, it truely was held up by the glue. It left silver rubbery strips...What should I do?
  • Ron Coons
    Ron Coons May 11, 2010
    cant imagine that they actuall used glue. what s the complete model number??? ill look up diagram
    President:
  • Hotpoint Master
  • 2,651 Answers
Theres a bottom trim that installs from under the doorwith 3 phillips screws, this is what holds the door in place. it probably rests under the hanndlesupport and is held up by this strip, take a close look at bottom of door and you see the removable metal strip..
Posted on Mar 20, 2008
The front glass of the oven door fell off, didn't break....but, how do I put it back on? Was it just glued?
Hello. Notice in pic 2 of the exploded diagram of the door, part 359 which is the bottom door trim, part# WB07K0379. I believe this holds the glass in the door if I'm thinking of the right model oven. The glass door steel cover (designation 314) is WB57K10049. I'm not sure if your glass panel was glued to the steel cover--that's why I gave the part number for it--just in case it can't be repaired. If you need more info or part numbers, leave a comment and I'll be glad to help you further!
Sep 21, 2015 | GE Profile Spectra JGBP90 Gas Kitchen...
I drip between the glass on my ge profile oven
The only way to clean this is to disassemble the door. Begin by opening the door about 1/3 and grabbing both sides. then pull and the entire door will come off in your hands. look for the screws that hold the door together. remove them and you can carefully separate the door and the glass to clean it.
Aug 13, 2009 | GE Profile PSI23NCR Side by Side...
How do you change the oven bulb in a GE Profile Convection oven?
Unplug or flip breaker to the range. Remove wire around glass bulb protector by sliding one side out of clip while holding onto glass protector so it doesn't fall into the oven and break. Unscrew old bulb, replace with new one. Hold glass bulb protector over the bulb and hook wire back into its clip. Voila! Back in business. (I didn't unplug it, but discovered that you can't turn off the bulb, so it shines in your eyes while the oven door is open. Also, very stupid thing to do, since the bulb could very easily have broken in my very clumsy hand and given me a bad shock. So do it right, and unplug!)
Jun 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Glass door GE JGS968
youlls need to remove the door forom the unit and disassemble the outer door glass, not a major deal, al ittle patience will get it done if oyou would like to know how to do it exaclty youll need to send me the model number so i can look it up for a part diagram..
Jan 15, 2009 | GE Profile JGS968 Gas Kitchen Range
GE OVEN/RANGE INSIDE GLASS ON DOOR SHATTERED.
You will need a window pack, part number WB56T10152 which is not hard to replace. You should be able to order it right from GE, or an appliance repair firm can get it for you, often without extra shipping if they can combine it with other parts they need to order. Should set you back just over $100. You can remove your oven door to make it easier to work on. Use a little screwdriver to pull down the little square hole you will see on the top of the hinge opening on the frame of the oven on each side. That little metal part will lock the hinge open. Next, lift on the door and pull it toward you. The hinge actually stays with the door and lifts right out of the rectangular opening in the oven frame. Reverse procedure to reinstall repaired door.
Nov 29, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Exploding Door
the old exploding door ploy...
01:00 hrs while sipping on a very fine IPA watch a bit of tellie the sound of glass shattering startles me from the kitchen. preparing to find the daughter's cat, still in the house after evaded bed time radar, on the counter. instead the front glass on the our GE Profile gas range, model JGB908SEK1SS, is slowly spider webbing into pieces. i grabbed the video camera and captured the event. GE sent out a repair guy to quote me a whopping $304.27 to replace their faulty part. foot note here...the range is four yrs old and hadn't been used in more than 24 hrs prior to the glass on the door shattering. i don't believe the glass had a "fracture to it in the production cycle at the factory". being a DIY guy the service tech ordered the replacement part for me. i just received the replacement glass from GE and it's white which would be OK if we hadn't ordered it in stainless steal. did i mention it's taken 2 months to get the replacement glass. i've attached a photo of the cleaned door awaiting installation. i really wish it had been the cat...77f7f82.jpg
Jun 09, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
foil was just protective heat tape, there is a track across the bottom of door that is holding it up,
Mar 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL44
can ya post a picture of the piece and the door for refrence? thanks :-)
Sep 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint RB787 Electric Kitchen Range Logo
322 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
