Question about HP LaserJet 2420 Printer
Hp printer 2420 is double printing same paper side
  • 3 more comments
  • mrwriter78 Mar 27, 2008
    My HP 2420 is double printing on the same page. What is at the top of the page appears again a bit lower down.
  • Anonymous Jan 08, 2009
    HP 2420 is printing a 2nd blank page evertime I send something, I have not changed any settings, I have updated the driver and it still prints a blank extra page.
  • rvhmelissa Jan 20, 2009
    Same problem. Anyone find a fix yet?
  • jpforte May 11, 2010
    what do you mean by double printing? does it complete printing the first sheet and then pull it back in and print again on the same sheet? Or does it print like a ghost image on the paper? Do you have a duplexer installed in the printer?
  • Anonymous Mar 16, 2014
    How do I use my double sided printer on my HP 4630
    Genius:
  • 3,587 Answers
We have a link on how to fix your own printer through this link(check for search box further down page)
Posted on Mar 20, 2008
How to fix hp 2420 printing blanlk paper and then paper jam
Check the pick up rollers in the tray and look for signs of wear. Most likely this is your problem.
Apr 09, 2014 | HP LaserJet 2420 Printer
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 17, 2012 | HP LaserJet 2420 Printer
I am using a hp laserjet 2420n printer and i have been trying to print on both sides of the sheet but i cant
For details, please click on this link and follow my instructions :- http://www.fixya.com/support/r7325259-double_sided_printing_using_single_sided
Aug 13, 2011 | HP LaserJet 2420 Printer
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    Double printing on page
    This is caused either by the fuser or the tonercartridge.
    The most common cause is the tonercartridge.
    You can test this by forcing a paperjam to stop the paper just after the toner but before the fuser.
    To force a paper jam print you can print a page from the manual feed tray and as the last third of the page enters the printer opening the door causes it to halt.
    If the double printing occurs before the toner is bonded to the paper by the fuser you should replace the tonercartridge..
    Dec 29, 2010 | HP LaserJet 2420 Printer
    I want duplex printing for hp 2420
    The only way to duplex print on a standard 2420 is to print the first page, then take that page and re-insert it into the paper tray face up. Then print page 2 onto the back of page 1. If you want to automatically duplex print then you need a 2420DN printer which has the duplexing paper path as well as the formatter board with the duplex firmware.
    Good Luck and Thank You for using Fixya.
    Sep 23, 2010 | HP LaserJet 2420 Printer
    LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
    i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
    May 06, 2010 | HP LaserJet 2420 Printer
    Blank printing
    Did you pull the plastic tape from the side of the cartridge?
    Nov 14, 2008 | HP LaserJet 2420 Printer
    Double side printing issue with HP 2420
    Try to default on your page setup.
    May 23, 2008 | HP LaserJet 2420 Printer
    Print quality problem
    Hi there sound to me like the toner cartridge is either faulty or leaking. Is it or has it been refilled if so remove cartridge vacuum out the insides of loose toner install brand new toner cartridge then test again. It cannot be the fuser unit as it will have quality problems all the time so try above and I hope it works for you.
    Thanks J
    Jan 14, 2008 | HP LaserJet 2420 Printer
    HP LaserJet 2420 Printer Logo
    200 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
