Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd-52525 screen is bright red can still see pitcure but way to red
  • Mitsubishi Master
  • 8,617 Answers
The color wheel usually controls the color, however with that model it could very well be a bad capacitor on the FMT . I would suggest a service manual before even taking the back off that model. It is fairly complex. Here is a link to where you can get the service manual emailed to you.
http://servicemanuals.vstore.ca/
Posted on Mar 20, 2008
SOURCE:
I have a mitsubishi wd-52525 tv and just replaced the lamp but the picture does not look as bright as before. no settings have been changed.
Try "initializing" a "factory reset" power on the tv then on the remote "menu 1,2,3 enter". Start the reset to default and see if the new refreshed settings help.
Mar 03, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Just bought a Mitsubishi WD-52526. With Brightness, Color, Sharpness, Contrast, Everything Video turned all the way up the Screen is still very dim. Is this a lamp issue?
It could be. Do you know if the previous owner ever changed the bulb? If not you may have to replace it. The bulb usually costs around 160ish. I would try it and see if it helps the brightness.
May 04, 2011 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Watching dvds
Good Day;
Make sure you have proper input selected, blue sreen normally means you have no video signal.
Good Luck, big IRISH.
Aug 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Static picture or flashing colors pictures wd-52525
HEY AWOOD,THIS SYMPTOM IS DUE TO POWER CAPACITORS GOING BAD IN THE POWER SUPPLY AND THESE CAPS CAN CAUSE A COUPLE DIFFERENT SYMPTOMS,YOURS SEEMS TO BE THE MOST COMMON.IF YOU'RE TECHY ENOUGH YOU CAN REMOVE THE BACK AND GET ACCESS TO THE TWO PLUGS ON THE LITE ENGINE TO TEST (WITH A VOLTMETER) THE 5 VOLT SUPPLY ON I BELIEVE PLUG J19 PINS 1 AND 3.IF LOW THEN REPLACE 6 CAPACITORS ON POWER BD. YOU SHOULD BE ABLE TO SEE IF THEY ARE BAD JUST BY A VISUAL INSPECTION.GOOD LUCK JOE TV
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
