Question about Asko 24 in. 1895 Built-in Dishwasher
Asko 1895 How do u install an asko1895? we are having problems
My flavel dishwasher wont work it just stopped dead during a wash and no lights are on now
Posted on Oct 28, 2008
    Sergeant:
  • 351 Answers
The most important thing is to screw it to the bench,there are four screw points two at the top and two on the side near the top if you look you will see the tags where they go.as far as the hoses go just make sure the drain hose is up high and not laying on the floor.hope this helps.if connecting to hot water it must be below 60 degrees.and you probably wont need a pressure limitin valve fitted to the tap.
Posted on Mar 20, 2008
SOURCE:
Dishwasher asko 1895 the pump the working the lights are flashing but the machine is not working
The lights flashing is telling that there is a fault in the dishwasher.
I am assuming you have emptied the dishwasher after the drain cycle failed to work due to the pipe block.
You will have to make a fresh start. Empty the dishwasher, turn the power mains switch off and on to reset the dishwasher.
Start a new cycle and see if flashing lights stop flashing. If still same problem you will have to note which light(s) are flashing and send a post on this page. There is a chance the impeller in the drain pump may have sufferred some damage due to drain block depending on how long the motor operated before you found the problem with the drain.
Jan 04, 2013 | Asko 24 in. 1895 Built-in Dishwasher
Unit has been flashing F1 and now doesn't seem to complete the cycle. Just keeps running.
The F1 error codes is a water heat fault,the control has determined that within 60 minutes that the correct water temp.has not been reached
The possible causes of that are
A burnt out heat element
A burnt out thermostat
Gene
Aug 22, 2011 | Asko 24 in. 1895 Built-in Dishwasher
Asko 1895 shows F2 outlet pump running no water in washer will not shut off have shut off power and restarted stll shows F2 with pump running ?
open the access to the pump and make sure thats its clear and that there are no foreign objects blocking the impellar from spinning. Unit will not start if drain pump is clogged
May 03, 2011 | Asko Dishwashers
It has been flashing an F2 error code and the timer starts at 65 then switches to "1" which stays on during the cycle. Now it will run for about a minute then stops completely. Can you suggest any parts...
Welcome to FixYa.
The "F2" for Asko dishwashers indicates either the unit is overfilling, or the valve itself has failed.
The problem is likely the fill valve, based on your description... "It has been flashing an F2 error code and the timer starts at 65 then switches to "1" which stays on during the cycle. Now it will run for about a minute then stops completely".
Depending on the series of dishwasher you have, determined by serial number ( I don`t mean the model... I got it is a 1895 ) because those Asko machines had a revision to their valves moving from a dual solenoid to a single, the single substituting all dual coil valve units.
i.e.
The original Asko number would be # 8057508 and available at most brick & mortar parts vendors or on- line places such as "repairclinic.com".
** turn off the breaker at the service panel before servicing the unit...safety first**
To check the valve will require the removal of the lower panel/kick plate or also referred to as a toe panel, and with the aid of an ohm meter and at least one wire removed from each/the coil, measure the ohm value of the coil.
The valve will be on your right...
i.e.
It should not read infinite, but rather 0 to 93Kohms.
That should move you forward and hopefully solve the problem. Let me know if anything is not clear or if you require further assistance.
Thank you for choosing FixYa and good luck.
** If you have any reservation or are not completely confident servicing this unit please call in an authorized Asko technician **
These can be very difficult to service for one inexperienced, I see so-called pros mess them up all too often.
Regards,
Macmarkus :)
Oct 07, 2010 | Asko 24 in. 1895 Built-in Dishwasher
Asko 1895
First make sure your door switch is making proper contact.If not replace it. If it checks out ok than your main control board is bad.
May 21, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko 1895
water in base remove dishwasher and tilt to side and it will restart,but you may have a leak,also check the inlet valve may not be closing fully.hope this helps.
Mar 06, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko 1885-1895 heater element replacement
Remover the lower front panel, and from there you should reach the element nut. Good luck
Feb 14, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko dishwasher
Most likely the main switch is bad.
Jan 02, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Dishwashers Logo
200 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
