Question about Refrigerators
Leaking water from the defrost
Recently our refridgerator has been spilling water into the fridge compartment and onto the floor. I think it is coming from the defrost. Is there an easy way to fix it? I'm wondering if ther is a plugged drain line somewhere.
    President:
  • Refrigerators Master
  • 2,651 Answers
Sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 20, 2008
Why is it leaking water onto top shelf
Most modern fridges have an automatic defrost that works by draining into a sort of funnel above the back of the top shelf.
The funnel is connected through the back of the fridge to a rubber drain tube that goes down the outside of the back to a heated evaporation tray under the fridge,
The hose and/or funnel can get clogged with disgusting yucky stuff, and the water spills over the top of the funnel onto the top shelf.
The fix is to clean all the bits. It's usually no big deal to take apart.
I have resorted to blowing through the tube from the bottom end and then cleaning up the mess, and brushing my teeth. Quite revolting but, that's the price I paid to become an expert.
Cheerfuls
Nov 20, 2015 | Refrigerators
Hoover Contour refrigerator HE383TF. Water is leaking inside the fridge. It appears as a puddle under the vegetable compartment and then leaks onto the floor. I have completely defrosted and then poured...
Could be the little red stopper at the back of the fridge on the inside has come off, and this is where the water is coming from, look inside on the lower shelf and you will see a round opening which should have a red stopper in it.
Dec 30, 2010 | Hoover Refrigerators
Our Jenn-Air refridgerator is 11 years old and is leaking from the back onto the floor. We looked in the back behind the cardboard panel and saw that the pipes around the( pump ?)located in the lower...
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 11, 2010 | Jenn-Air Refrigerators
My fridge leaks underneath
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Hope this helpout......
Jul 29, 2010 | Jenn-Air JCD2389G Side by Side...
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Leaking fridge ge
1) Check to make sure nothing has spilled in it. I had a bag of peas split open once and they were blocking some area and causing an airflow problem. I would then get Ice build up then it would thaw and spill on the floor.
2) I'm sure you have done thisw but make sure a water line does not have a split or pin hole.
Aug 09, 2008 | Refrigerators
Refrigerators Logo
319 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
