Question about Apple PowerBook G4 Mac Notebook
Installation of 1gb 200 pin sodimm 128mx64
I was told it is a plug and play but I have no idea how to install it.
  • dsuarez Mar 20, 2008
    Hi I have a mac and i wanted to know how to install a memory chip.
  • Darren Perlmutter
    Darren Perlmutter May 11, 2010
    What model mac are you using. Notebook, or Desktop?
  • 78 Answers
Even better - take a look at this post.
Make sure you pick up the necessary tools, and most importantly, discharge static electricity. It's not a bad idea to ground yourself, either. Wear rubber soled shoes. :)
Posted on Apr 07, 2008
I have a Sony Vaio PCG-K25 laptop and am trying to upgrade to a gig of memory. Is it possible to do this? I put 2 512 memory chips in the slots but it only sees 448. Using Kingston Technology 512 mb...
This laptop has its own graphics card that doesn't rely on system memory for the graphics.
There should be no reason why its not detecting all 1GB of ram that you have installed.
Open the ram cover and make sure that you have clipped the ram into place properly.
Regards.
Jul 01, 2010 | Sony VAIO PCG-K25 Notebook
Whatis the maximum memory the medion rim2520 pc
Standard Memory : 512MB or 1GB Maximum Memory : 2GB ( 2 x 1GB) Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM
Oct 08, 2009 | Computers & Internet
Problem while upgrading my RAM
some systems require matching pairs, so since you are using mismatched, it may only recognize 1 GB of the 2gb module
Sep 27, 2009 | Dell Latitude D630 Intel Core 2 Duo T7250...
Did crucial memory scan. they recommend 2- 1gb 184-pin unbuff dimm 128mx64 ddrpc2700 installed both sys. did not come up. with 1gb stick at a time sys. comes up fine. but not...
DDR SD ram only. Page 124 of you manual. Dimms with more than 18 pieces are not supported on your board. Seven venders for approved list of RAM chips with model numbers.P15 of you manual.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Jan 17, 2009 | ASUS A7S333 Motherboard
RAM upgrade is not working
A 200-pin PC-3200 SODIMM should work in your machine but it will clock down to 333MHz. Your computer has 2 slots with a max of 512MB per slot (1GB total system memory). For maximum compatibility you should stick with a low density (16-chip - double-sided) PC2700 DDR-333 SODIMM with a CL of 2.5. Link below to see an example:
http://crucial.com/store/listparts.aspx?model=Pavilion%20ze4300%20Series
-E
Dec 25, 2008 | HP Pavilion ze4365us Notebook
Memory issues
CHECK RAM ONE BY ONE, IT MAY BE POSSIBLE THAT THE RAM IS FAULTY
Nov 09, 2008 | Dell Inspiron 9300 PC Notebook
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Memeory does not show up
sure.
step one...same or different maker(not that important, but nice to know)
step two..speed of the memory(usually in nanoseconds) these need to be within 25% of each other, max. Same is the best
step three..i don't see the processor compatibility speed on the second set you installed. First one is 266MHz..what's the second set rated at?
I know it fits mechanically, but that's only the basics with memory swapping.
Mar 24, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A15-S127: Memory does not show up
Is the BIOS up to date? if not you can download latest BIOS update from support.toshiba.com
Mar 12, 2008 | Toshiba Satellite A15-S127 Notebook
Acer 3500 Problem
I think the problem may be the memory is not up to standard for this laptop. The mobile sempron 3500 notebook takes DDR2-667 PC2-5300 200 pin SODIMM memory.
Dec 15, 2007 | Acer Aspire 3100-1405 Notebook
Apple PowerBook G4 Mac Notebook Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
