Broken tv !
The tv is new and it will randomly not work the screen will be discolored it is a flat screen it did this once a while back i left it alone for a month or two plugged it in it worked fine for weeks it is now back to not working
  • 8,617 Answers
What model? Is it still under warranty? If so call the manufacturer they should honor the service if its still new.
Posted on Mar 20, 2008
SOURCE:
I dropped the tv, it's not bad, but it needs repair. My question is is it the TV panel or LED light? There's discoloration at the top running down the screen, like water dripping. Any help, thanks!!
If it looks like liquid dripping you broke the liquid crystal Display display, otherwise known as the LCD. This is probably the most expensive part of your TV. You can look into getting it fixed but it's probably cheaper to buy a new one. Alternatively if you can find someone selling the exact same model with a broken back light then you could swap out the LCD... But that would require a fair level of electrical skills.
On the other hand, If you had broken the backlight then the picture would be very dim on one side, or completely black (but shining a flashlight would enable you to see the image on the screen to some extent).
You might be able to sell the broken TV on craigslist for maybe about $50 (total guess here, check around for going prices)... But due to the weight it probably would only be worthwhile to sell it if someone could pick it up ... So eBay wouldn't really be an option.
May 24, 2016 | Televison & Video
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
A vitamin bottle was thrown at the tv and now its discolored on the corner. it's 2 years old. can this tv be fixed? it's 52 inch tv
Sounds like the screen was broken from the impact.
They can be replaced but are very expensive. Between labor and the cost of the screen it may not pay to replace it
Apr 05, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My Toshiba 42hp83 has a rectangular area of the screen that changes colors randomly from the left-center of the screen down to the bottom. After about 20 minutes of the TV being on, the problem usually...
We had a similiar issue with our SAMSUNG Plasma TV. It had a 2'or 3" vertical bar of random colors on the right side of the screen. It would also go away but then come back. Fortunately for us the TV was still under its original 1yr manufacturers warranty. We called the customer support and they scheduled a service call. The TV repair man took our TV to the shop and replaced the defective components. It took about 3 weeks for the repair.
Nov 06, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
LG Television 37LB4D "Rebooting"
Ours is crapping out just like yours. Picture goes out, "black and white squiggles" appear in the top left of the screen then TV input appears, then it either repeats or gives me my picture back. This happens with both the HDMI slots (tested all 3) and both Component slots. Seems like the bulb or a circuit board on the TV is faulty. What a piece of ****, never spending another dime on LG products. I did get it to come back by hitting the back of the TV with a good slap, but it gets really annoying.
Jun 14, 2009 | Televison & Video
Yellow discoloration on screen
the screen is yellow green color all the we have had it worked on once already does anyoblemne have any comments on how to solve this problems?
Jan 27, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Broken Screen
most are. you need to open the lcd and get the model number from the back of the lcd itself. you will need manufacturer, model number and revision number.
if the glass is not cracked, you may simply need a new backlight.
Nov 17, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 37LC7D remote doesn't work
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Sep 06, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Ekse
