Question about Hitachi 53UWX10B 53" Rear Projection Television
T.V. will not turn off
After t.v. is turned off, the red light is still on on the front of the set. Already have had a tech out to repair 2x in the last 2 years so I am not super excited about calling him again. Any suggestions I can try myself? I did try unplugging it and letting it sit for awhile but it did not work. Thanks in advance.
  • juward Apr 05, 2008
    I've had a similar issue from day 1. I would shut off the T.V. at night and then wake up in the middle of the night and find it on ... not every time but way to often ... it was spooky. After this had happened dozens of times, I determined that it was only happening when the set was receiving an HD channel at the time it was shut off. So now I make sure that we're not viewing an HD channel when it is turned off ... and it doesn't come back on. I know it sounds nuts but it works.
    Scholar:
  • 87 Answers
You have a stuck relay. Check S902 in the power supply.
Posted on May 10, 2008
SOURCE:
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Sony KP 48S65 no picture good sound
The blinking red light should happen for 15 seconds when set is turned on--set is looking at the 3 picture tubes to see if voltages are all there--if not it does not turn the tubes ON.
Going to be a shop repair unless you get a older tech to come to home to try to fix it. Considering age of set it may be time to replace it?
May 29, 2012 | Sony KP-48S65 48" Rear Projection...
Two red lights flashing under ink icon and yellow "E" flashing
E it measn the Printhead is not detected or printhead not installed., Its normal if you have E error that you will have 2 flashing red light check color ink or black.
Now try to reseat the printhead of the printer, YOu need to removed first the ink cartirdges before you can remove the printhead.
Now if you already reseat the printhead 2x and the ink cartridges It means the printhead is defective call Tech support for printhead replacement toll free 1 800 235 6325
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
SD Tech you answered my panasonic tv with 3
OK, here is what I suggest you do----remove the light box from the set and unsolder all pins on both convergence chips----see if the set will turn on and light up---you can turn the set on with the remote--its receiver is at the top of the three black lens.
sd tech
Oct 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Screen turns blue then shuts off.
I already replied but once again..
Symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Sep 05, 2008 | Toshiba 51H84 51" Rear Projection...
4100 Light flash no connection
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Jul 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
No sound, no picture and a red light blinks on front panel
If I remember right the set is blinking a code, dont remember which code, but what happened something on the power board failed and knocked out the 5vdc regulation? The power board will most likely need replacement, this should be done by a qualified technincian or someone who knows how to dissassemble/ repair set.
Jul 07, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
