Question about Broan-NuTone Allure II QS230SS Kitchen Hood
Everything stopped working?
I HAVE THE SAME PROBLEM WITH A ALLURE 2 JUST STOPED WORKING ?
BUT POWER IS COMING IN THE UNIT ALL SEEMS OK, CHANGED THE LITTLE GLASS FUSE ON THE CONTROL UNIT.STILL NOT WORKING .CHANGED THE CONTROL UNIT ITSELF STILL NOT WORKING
HELP !!!
  • 38 Answers
Replace the transformer. Part #R501025 Its the smaller transformer of the 2. It has blue/yellow wires coming out of it.
I do service calls for broan-nutone.
Posted on Jun 14, 2008
SOURCE:
No power
Check the power cord first. If it is OK, check the fuse inside the device. There is glass cargtridge type, repalcable fuse, can be located on the main power supply regualtor board.
Mar 15, 2012 | Philips CDR765 2-Disc CD Recorder
Last night both fan and lights worked on my hood fan and lights. This morning neither are working. Checked house fuse box - everything ok there. what could be the problem does the allure have a fuse inside...
could be simething as simple as a disconnected wire, prior to calling for help, check these items if you feel okay with that , first turn off the circuit breaker and where the house wires come into the unit,, remove the wire nuts and check for burned areas,, if thats ok, reattach them and move to the switch or switches, unhook the wires, ( make note where each one goes ) and check them with a meter , this is probably where your problem will be,
Jul 10, 2011 | Broan-NuTone Allure QS130SS Kitchen Hood
I have aproblem with my Buick Allure both low beam stoped working.The high beam works OK. Checked the fuses and there OK can you help
suspect low beam head light fuse, check fuse if ok suspect that both low beam head lights are burned out ( it happens) ,if ok suspect headlight dimmer switch.
Nov 16, 2010 | Chevrolet Avalanche Cars & Trucks
Accessaory power plug stopped working
Check all the other fuses in the car,sometimes they tie a few together.
Mar 29, 2010 | 2004 Chrysler Sebring
Don't cool-no refund/satisfaction from Oster.
Ok, fist problem was unit quit working..if it quit cooling yet lights still worked inside and still had power readings on door is not power coord. If the unit stoped cooling is probably fuse and there are two of them in back of unit. One fuse clearly can be seen, the other is coated with a black shrink fit coating and is not well seen. This second fuse is the problem, you will need to replace it. I have same unit and this is what I had to do to get it cooling again.
Jan 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Changing fuse on Nutone Allure Ws2
Hi Mertl, I sure hope you found the solution since, but I am posting the answer for other people like me (and you) who need to find it !
The service manual says:
To replace the fuse:
1. Disconnect power at service entrance.
2. Remove filters, bottom panel, light wire harness, and air chute.
The fuse is actually right behind the fan controls, so to access it you need to disassemble everything that's in the way.
BTW, for anyone wondering if it's the fuse that's faulty, here's a clue:
If the fuse has opened (blown), the green fan-level indicators
will operate properly when the fan buttons/switches are pressed
- but the fan and lights will not turn on.
The fuse is a 5 x 20 mm, 10 Amp, Fast-Acting, 125V (min.).
Good luck all !
Aug 16, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
ALLURE II STOPED WORKING ??
If nothing is working Lights/Motor Nothing, Its the small transformer. Theres 2 transformers. you will see blue and yellow wires coming out of it. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Mar 20, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Feb 18, 2008 | Kitchen Ranges
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
477 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Steve Allison
Steve Allison
Marvin
Marvin
Paul Bade
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
