Question about Gateway GT5408 PC Desktop
No signal to monitor
I turn on computer and power light comes on and im not getting a signal to the monitor, (just a blank screen) i changed the video card and i still dont get a signal. could my problem b in the hard drive or maybe the motherboard, ichecked all connections sevral times and i dont know what to do next , can you please help me .
Checking if anything in ur computer is plugged in
or unplug the power wire from the computer, turn the computer on twice (there is no power in it so it wil run like 1 seconds then turn off again), then plug the power back in and turn ur computer back on,
GOod luck
Posted on Aug 02, 2008
Sounds like a bios issue. Check your manual for resetting your bios to default parameters. Good luck.
Posted on Mar 20, 2008
Toshiba laptop pas409e-d screen is black
Step 1:
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Causes a Computer Monitor to Go Blank b> While a blank screen may be caused by a general power outage, more often it's a problem with the screen itself. It could be a loose video or power cable going to the monitor. If that's the case, you can get the screen working again and be back in business in a few minutes. b> Power Problems All the power might be off due to a bad outlet, switch, fuse, or circuit breaker. If you hear no sound coming from the computer and its power light is off, check the power connection and breaker or fuse. Video Cable Many times the cause of monitor blackouts is a loose video cable connection. This might happen if you move the monitor or the cable. The video cable runs from the back of the computer to the monitor. It has a multi-pin connector on each end and both of them screw down securely. If the screws aren't tight, either connector could become loose. If that happens, the video signal could stop suddenly and make the picture go blank. Check both ends of the connector to make sure they're firmly seated and the screws are tight. The cable itself might be bad.This is unlikely, but possible. b> Display Power The monitor must have power. If the power light isn't lit on the monitor, it may have been turned off or become unplugged. Press the power button to make sure it wasn't accidentally turned off. Make sure the monitor is plugged in. If it's connected to a power strip, check that the power strip is on. If that checks out, unplug the monitor and try a different outlet. Power strip sockets can sometimes fail. Flat-screen monitors may have a power-brick-style adapter. It, too, has connectors. Follow the power cable from the monitor's power plug back to the monitor. About halfway up you'll find a thick rectangular plastic brick. The power goes into a modular-style equipment socket. This can become loose. Follow the wire the rest of the way to the monitor. It connects to the back of the screen with a small round plug. Check that it's firmly plugged in. If everything's plugged in right and the power light on the monitor's still off, the power brick might be bad. b> Video Card Some computers have a separate video card inside. It may come loose and cause a blank screen. If this is the case, open the computer and inspect the video card. Sometimes removing and reseating the card will fix the problem. If it has to be replaced, most video cards are not expensive.
b>
Feb 15, 2013 | Computers & Internet
My acer monitor come on and screen go blank
Step 1:
Feb 15, 2013 | Acer Computers & Internet
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
Tells me I'm in a power saver mode. Screen is blank. Model is 2241V
That message comes up when the monitor doesn't get a signal from computer, and enters power save mode until computer comes on. This usually means that the computer's not starting up when you turn the power on. It may also mean that some problem has occurred with the computer's video circuitry.
Begin by checking that the computer is actually starting up properly. Look for the normal startup signs (lights on the computer showing power and disk access, fans running, sounds through the speakers). If you're sure that the computer is working and getting into Windows, try another monitor. This will tell you if the monitor is bad or if there's a video issue with the computer.
Jun 03, 2011 | LG Computers & Internet
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Blank screen
When you say "When I turn on the computer the monitor acts like it is getting no power", do you mean the light on monitor doesn't come on or it does and it states it has "No Signal"? If it says no signal then it is receiving power just no signal from computer. What kind of connection is it? Digital(white) or analog(blue)? Is the keyboard wireless or is it PS/2?
If the keyboard isn't wireless and you're plugging the monitor in correctly I would say it's a power supply issue. Try changing the outlet you're using and/or bypass the surge protector to plug directly into wall.
Jun 24, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Gateway GT5408 PC Desktop Logo
261 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
