Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Hooking up a laptop
When i hook up a vga cable to my laptop to go to my tv to use it as a monitor my tv says it is not connected any solutions thanks
  • 4,234 Answers
You must enable the monitor output. This is a function combination. Look for the key with the diagram of a screen on it. Usually the first pressing turns on the monitor as well as the screen, the second leaves the monitor on and turns off the screen, the third brings it back to standard (screen only).
Dan
Posted on Mar 20, 2008
Want to use TV as monitor for laptop
There is no way to hook the TV to the laptop. You can hook the laptop to the TV but not the other way around. It is done with a VGA monitor cord. The same one that you connect to your regular monitor. Your TV will have a plug labeled VGA.
Nov 23, 2013 | Televison & Video
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
HP Laptop to TV
You cannot connect VGA OUT to component IN on your TV without using a converter. However, You can connect VGA OUT from your laptop to VGA in on your TV using a VGA cable just as long as your TV has VGA in. You will need to hold the FUNCTION or FN key on your laptop while press the F4 or F10, whichever F key has the picture of the monitor on it. This will switch your laptop from LCD to external display or both.
May 02, 2009 | HP Televison & Video
I have a Dell latitude D600 laptop
The D600 has no TV out option, the only Output for visual display is the monitor VGA port.
You would need a converter for the normal VGA to DVI Cable.
Mar 22, 2009 | Dell Latitude D600 Notebook
I DON'T GET A PICTURE WHEN I HOOK UP MY LAPTOP TO MY TV MONITOR.
on your laptop keyboard, press function button & monitor button at the same time .
Oct 18, 2008 | Computers & Internet
How do i hook up a tv monitor to my campaq computer
usually laptops have vga conector for external display, you may need a cable, vga cable.
vga cable varies depends on the connection that you have on the tv, if your tv supports vga connectors thats great, some tv doesnt have that option, thats where adapters go in to adapt what ever ports or connections you have on your tv.
some of the cable adapters that you might need.
vga to hdmi.
vga to rca.
vga to dvi.
hope that helps.
Oct 17, 2008 | HP Compaq Presario V2000 Notebook
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
Jerry Greenberg
Jerry Greenberg
