Question about Freezers
Poor tasting Ice
I have a Kenmore refrigerator with top mount freezer. In recent weeks the ice has begun to taste bad. I do not have a manual for this unit and don't know if there is a filter on the ice maker. Any help would be great!
  • 168 Answers
There could be a filter installed. The filter usually looks like a long tube about 6-10" long and about 1-3" round.
Try to located the water line. This will be either a copper or plastic tube about 1/4" diameter and will be going into your fridge from the back of the unit.
The filter could also be located at the point of where the water is being supplied from. Possibly under your sink or it could of been tapped into another line in the basement if you have one.
If you located a filter, you will be able to see if you would be able to remove it and replace it on your own. It usually takes a couple of wrenches, but MAKE SURE YOU SHUT THE WATER SUPPLY OFF FIRST before attempting to remove it or else you might have to go swimming. (Actually it's a small tube, so not a lot of water will come out, but you still need to shut off the water supply to the fridge. Then you can bring the old filter into your local hardware store and get a replacement.
I hope this helps.
Good luck.
Mac =)
Posted on Mar 20, 2008
I hope this helps.
Good luck.
Mac =)
French door / lower freezer. The icemaker makes ice fine until tray is about full and then slowly drips water until about 1/8 of ice is frozen together with a upside down brown ice cycle fused to them....
The most common reason for this is that the fill valve for the ice maker is sticking slightly.
The brown ice comes from the leaking water sitting there on either the kickout bar or the gears and you are getting some residual rust deposit.
You will need to take the fill valve apart and clean it or possible replace it, I also recommend installing a water filter for the ice maker if you don\'t have one or replace the old one.
Calcium deposits in water are real hard on these small valves.
Oct 10, 2013 | Jenn-Air Freezers
The ice from my ice maker has a chemical taste...how do I get rid of it?
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
Mar 30, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
My ice cubes have a funny odor/taste.
Does your refrigerator have a water filter? if it has one it will be in the kickplate/grill below the freezer door. If it has one replace the filter.
Aug 17, 2011 | Whirlpool Freezers
I have severe ice forming in my freezer.
On this unit the shelves are the cooling coils and carry the refrigerant (freon) through the system. They will attract the warm moist air by design, so if you have an air leak in the door or elsewhere it will tend to build up there first.
This being said you need to check something else first. Make sure the other shelves are cold. If they are frosted and cold like normal then you most likely have a door that is not closing all the way or a bad seal. If the lower shelves are not cold then you have a system problem, typically a refrigerant (freon) leak that is causing the top shelf to absorb most of the work and not enough refrigerant to flow to the bottom shelves.
I hope this helps
May 06, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
Apr 05, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Water does not seem to be flowing into ice maker.
Hi and I hope this will help. You can manually turn the timer and see if any water is dispensed into the ice cube tray . If no water is dispensed check if the valve is any good . A solenoid in the valve opens to allow water in to the ice maker. Sometimes timers stick too.
Jul 05, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
102 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
