Question about Epson LQ-2180 Dot Matrix Printer
Print my epson lq-2180 from dos
Hi! i've been using epson lq2180 since last year and since i switched to my latest dell inspiron computer, i have to use the "USB to Parallel" adaptor to connect both printer and pc. the problem was the computer cannot detect the printer and sometimes when it detects (hurrah!!) still i cannot print from my dbase3 program which is a DOS-based program. do i hv to buy software program?should i buy an expansion card (PCI card) that built-in with parallel port? if there is any program that i can use kindly help me...thanksss!!
SOURCE:
SOURCE: Connecting Epson TM U220D printer with Laptop (having Windows XP)
If you have the Cables2GO USB to Parallel converter, it is a pain to get working.  Go to Radio Shack and buy the GigaWire USB to Parallel.
Then once plugged in, go the printer that will be using the converter.  Go to the printer properties, select the PORTS tab.  Select the 'VIRTUAL PRINTER PORT FOR USB'.  That worked for me!
Posted on Nov 12, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
  • 3 Answers
SOURCE: epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Posted on Feb 02, 2009
SOURCE: EPSON FX 2175 always printing JL 1284.4 @GJL
sometimes the printer head is locking/stopping at the right side
Posted on Feb 05, 2009
  • 4 Answers
SOURCE: epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Posted on Feb 20, 2009
How reset printer epson lq-2180 to factory
An Epson LQ-2180 is an old dot matrix printer, it cannot be programmed like newer network printers. All it has is a panel in front where you can select a font, the pitch of the font and paper type. There is nothing to reset.
https://files.support.epson.com/pdf/lq2180/lq2180u1.pdf
Feb 19, 2017 | Epson Office Equipment & Supplies
I want to download drivers epson LQ 2170 for winxp.
Hi my system win xp
and i want 2 install the driver of Epson LQ-2170
I searched every where,pls advice
Mar 22, 2011 | Epson LQ 2170 Matrix Printer
I have Epson LQ 2180. When Ever i load paper from rear tractor feeder it loads the paper and still shows the paper out LED. If i press Load/Eject button it only loads the paper not eject. I have cleaned...
Hi
My friend we have LQ2180 in our office, there i a lever in the right side of the printer that indicates when you print your document. Adjust to upward to print the document from rear tractor and to print from the front push the lever downward. Maybe you accidentally, push down the lever.
Any problem, just message me. Regards.
Jan 11, 2011 | Epson LQ-2180 Dot Matrix Printer
LQ-2180 hasil print putus-putus & ketika sedang print bisa berhenti sendiri, apa solusinya bosss..??
TOLONG,,, BAGAIMANA CARA MENGATASI PRINTER EPSON LQ2180 YG HASILNYA PUTUS-PUTUS DAN BURAM,,MOHON BANTUANNYA
Dec 25, 2009 | Epson LQ 2170 Matrix Printer
Paper out
Have you considered buying an ink jet printer? You will find your money will be well spent. Epson all-in-one printers can be bought for less than $100.00 when they are on sale.
May 27, 2009 | Epson LQ-2180 Dot Matrix Printer
Printing
I can not print with Epson printer Lq-2180 , wheras I install driver into windows2000 And add printer, when i send command print ,the printer do not reflex.
Oct 31, 2007 | Epson LQ-2180 Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
93 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
