Question about Sony KV-35S42 35" TV
Sony kv-35s42 no picture, good sound timer light flashing
Two 35 inch Sonys were given to me with identical problems no picture, but good sound and time delay light flashing. What can be the problem??
  • lala42 Jun 02, 2008
    I have the exact same tv (Sony KV-35S42), and exact same problem (good sound, but flashing timer light and no picture).
    Read the posted solution, but I don't know how to do that myself. Is it possible to do at home with step-by-step instructions, or do I need to hire a professional?
    Thanks!
    Genius:
  • 1,694 Answers
Usually, the CRT is bad......re-juvenation is a temporary fix at best........try adjusting screen control on CRT socket module.
Only other possibility is solder pins of vertical output IC.
Posted on Mar 20, 2008
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Sony kv 35s42 sound but black screen and constantly blinking stand by/timer red light
Your vertical IC will need resoldering. If you can take this board out and inspect the pins under the vertical IC, you will see rings around the IC. This is a common problem for you model of TV. Hope this helps...show a few hands of support.
Dec 14, 2010 | Sony KV-35S42 35" TV
Sony kv-35s42 35" tv picture blinks off and on
my best advice would be to check power supply for faults, bad capcitors etc to r/o the possiabilies of a power failure.
Thanks
Jun 26, 2009 | Sony KV-35S42 35" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Blinking screen
Bad CRT...no repair.................................T.
Mar 11, 2008 | Sony KV-35S42 35" TV
Blinking screen
ON THE 36 INCH SONY THE PROBLEM LIES ON THE PICTURE TUBE.THERE IS A LEAKAGE EITHER HEATER TO CATHODE OR G1 INSIDE THE CRT.THE ONLY WAY TO FIX IT IS REPLACE THE CRT OR HAVE THE CRT GUNS CLEANED THRU PICTURE TUBE TESTER/RESTORER/REJUVINATOR AVAILABLE ONLY FROM TV TECHNICIANS.GOOD LUCK.4TUNE.
Jan 09, 2008 | Sony KV-35S42 35" TV
Timer light blinking
POWER SUPPLY PROBLEM.YOU MUST HAVE SOMEONE REPLACE TWO TRANSISTORS,VARISTOR,FUSIBLE RESISTOR,4 CAPACITORS & HORIZONTAL OUTPUT TRANSISTOR & RESOLDER PINS ON HORIZONTAL DRIVER TRANSFORMER.GOOD LUCK.4TUNE
Dec 05, 2007 | Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
Sony KV-35S42 35" TV Logo
124 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
