Question about RCA DRC8320 DVD Recorder/VCR
Power problem. i have a RCA DRC8320N. My surge protector tripped. I reset the strip and everything else worked fine. However, my dvd/vcr unit won't power up. any ideas on what i could try to fix the problem. i've even tried using other outlets and still nothing happens.
  • 4 more comments
  • Anonymous Mar 20, 2008
    same prob
  • rcboyd8199 Mar 20, 2008
    I pulled the case off and there is a fuse inside but it doesn't look blown. There is no visible damage to the electric cord.
    The fuse is still intact. I've looked closely at the components on the board. There's a transistor that has like a white residue on it while none of the other transistors have it. I don't know if that means whether the transistor is blown or not.
    something i just noticed is i hear a little noise when i plug it in. it's like a clicking sound.
  • andoo545 Jul 24, 2008
    i hit power. nothing. unit has very few hours on it less then 20. dead. no display.
  • 4751havana Jul 31, 2008
    just stopped working. I don't know when. Won't power up. tried several outlets that I know are working. I used the remote, and the buttons on the unit. I tried to eject disc, I even swore at it...nothing
Hold the standby button for thirty seconds with the unit plugged in after thirty seconds release and un pluge the unit leave the unit off for thirty mins. it should re-set
Posted on Jul 24, 2008
  • 2,130 Answers
1. Make sure the AC outlet is good.
2. Make sure there is no damage to the AC line cord.
3. Look to see if there is a fuse at the rear of the unit. It's usually located inside a black circular housing with a screw off cap that says "fuse".
If not, unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Mar 20, 2008
  • SHARCNET-USA
    SHARCNET-USA Mar 20, 2008
    Can you remove the fuse and hold it up to a light and see if the the internal wire inside the fuse is intact? There may not be an discoloration on the glass.
    If it is ok, then I would suspect you have a problem in the power supply and was caused by the surge. You might also try looking to see if there is another fuse within the power supply.
    You might be able to file a claim with the power company. Explain what happened (tripping the surge protector) and you may be able to have it repaired or replaced if the power company was at fault.
    - Jim
  • SHARCNET-USA
    SHARCNET-USA Mar 22, 2008
    The white residue is most likely a heat sinking compound. It's used to help draw away heat from the transistor to the heat sink its mounted to.
Wont power up, after we had a power surge. It was connected to power strip surge protector, but has not been able to power up since. can it be a fuse problem, or more? magnavox dvd recorder mwr10d6
Apower surge can travel quicker than a surge protector can activate. And a replacement fuse may not fix your DVD. On one occasion I did replace a fuse in one of these after a power surge and the DVD/VCR did comeback to life. You may try...but the odds are against you and you will have to purchase a new one!
Jan 24, 2010 | Philips Magnavox MWR10D6 DVD Recorder
I need a manual for this product. Any chance I can download one? RCA DRC8300N DVD Recorder / VCR Combo
I see RCA no longer has any manuals for that unit. But, is this the exact model number? I mean like I have an RCA DRC8335 VCR/DVD recorder, so I am wondering if it is similar? If so I could work out something for you. Email me at jmsekola@citizens-tel.net if you think I can help with my manual.
Jan 01, 2010 | RCA DRC8300N DVD Recorder/VCR
My DVD Recorder & VCR (DRC8320N) has Hello on display
Even though the power light may be off the unit is still on. It will be warm on top. Unplug the unit for 30 minutes and plug it back in, that will usually reset it.
Dec 03, 2009 | RCA DRC8320 DVD Recorder/VCR
Will not come on
RCA DRC8320N DVD Recorder/VCR
Symptoms:
Seems to have no power, no lights on front lit, if listened to closely one may hear a "click click click" sound.
Solution: Replace C232 on power supply board.
Additional technical info:
In this design, the switching power supply feedback is from the 5 volt standby rail only, which is odd. The problem is caused when C232, the first filter capacitor in this rail and the sampling point for the feedback circuit, opens. The clicking sound is transformer rattle as the power supply restarts repeatedly.
Aug 03, 2009 | Televison & Video
42" westinghouse flat screen wont turn on
Some surge protectors fail just when most needed.
Jun 19, 2017 | Westinghouse TX-52F480S 52 in. LCD TV
Drc8320n vcr dvd combo says hello and pls wait over and over again.
Replacing a simple capacitor on the power supply just brought my unit back from what I thought would be the junk pile....
Read this.
Yes you can do this yourself....
http://forums.afterdawn.com/thread_view.cfm/707232
Jan 26, 2009 | RCA DRC8300N DVD Recorder/VCR
Initial setup drc8320n
I feel you pain. My wife bought me this unit about two years ago and I wanted to transfer some VHS tapes to DVD but there was no rush to do this and besides I had another VCR and a VCR/DVD combo unit. I finally opened the box the other day and proceeded to hook everything up and I had exactly the same problem. The unit says "HELLO" on the screen but will not advance to "PLS WAIT" or "INITIAL." So essentially, the unit is dead since without doing the initial setup none of the buttons on the front of the unit or the remote function. I e-mailed RCA and received a response that stated, "Audiovox acquired RCA as of January 1, 2008. The transfer of parts and information is still in process. However we did not acquire this portion of RCA so we do not handle this product i'm sorry for the inconvenience." So in other words and according to what I've read on the internet about this unit it's a total pice of junk and you can't get any technical assistance about this problem or replacement parts. The only thing one person told me was to hold down the power button on the left side of the unit for 30 seconds and then unplug the unit and wait a few minutes and then plug it back in to see if it resets to the factory default. Guess what, it didn't so I've totally wasted $200.
Apr 26, 2008 | RCA DRC8320 DVD Recorder/VCR
Dvd Recorder+VCR Combo Model#DRC8320N
CALLED 1-866-775-0976..WAS ADVISED IF PURCHASED LESS THAN 1-YEAR AND HAVE RECEIPT..SEND MODEL DRC8320N..TO: VENTURER ELECTRONICS..203 EGGERT ROAD..BUFFALO, NEW YORK 14215.....FOR REPLACEMENT PRODUCT....ANDREW REP..STAED THAT RCA WAS BOUGHT OUT BY AUDIO BOX COMPANY....SENDING MINE..GOOD LUCK....FROM : AFM1PGE.COM...GOOD LUCK!
Sep 12, 2007 | RCA DRC8300N DVD Recorder/VCR
RCA dvd-vrc combo model DRC8320N
RCA MODEL DRC832ON..NEED REFERENCE # FROM SUPPORT TECH 1-866-775-0976 TO REPLACE PROCUCT..RAC SOLD TO AUDIO BOX..SEND DRC8320N TO: VENTURER ELECTRONICS, 203 EGGERT RD, BUFFALO, NY, 14215..WHEN YOU RECEIVE REF #..NEDD TO HAVE RECEIPT FOR PRODUCT LESS THAN 1 YR FOR WARRANTY TO BE EFFECTIVE
Jul 23, 2007 | RCA DRC8300N DVD Recorder/VCR
Blank screen, power light clicks on and
This sounds like the common problem for this set. A bad connection in the sweep section or a bad flyback and a bad horizontal output transistor. Good Luck.
Aug 08, 2006 | RCA F36444 36" TV
RCA DRC8320 DVD Recorder/VCR Logo
225 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
