Question about Teac Audio Players & Recorders
Tape deck belt replacement
I need to replace belts on my old TEAC V400X tape deck. Opening the tape recorder, i have found out that maybe 2 belts would need to be replaced ? Is that it...if yes, what are the dimensions of those belts ? I want to replace them by parts not necessarily genuine.
Thanks,
Josée
SOURCE:
  • 518 Answers
SOURCE: Tape deck not working
Sounds like a motor problem. Try turning the motor by hand to see if it's bound up.
Geno
Posted on Feb 27, 2008
  • 4234 Answers
SOURCE: My TEAC A550RX stereo cassette
If the unit ends up in the middle of a cycle, the front panel will appear to be unusable. With a unit that has been idle for a long time, the belts and motors may be a little sluggish. This unit needs a general overhaul and the belts replaced. This should not be a major expense. Figure about $10 in belts and your ocal labor charge for the repair. If I remember correctly, this unit uses both a flat and square belt.
Dan
Posted on Apr 01, 2008
  • 518 Answers
SOURCE: DEAD LEFT CHANNEL!!
The most common problem is a dirty record<>play switch inside the unit. Try this: Using a blank tape, press and release record/play buttons several times. This can clean the switch a bit. Then play a tape. If it fixes the problem, then you need to take the unit apart and use a plastic safe spray cleaner on the switch (Check at Radio Shack, their tuner cleaner Catalog #: 64-4315 will work fine). Spray it into the switch and then work the switch with the buttons several times.
Hope that helps...
Geno
Posted on Apr 04, 2008
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
robotek
  • 1512 Answers
SOURCE: TEAC V770 3head tape deck.
Hi saabangerman
The unit sounds like it has a take up clutch or takeup idler problem. Check all the drive assemblies in the unit. Remove the cover from the front of the transport inside the cassette well, and check the condition of the idlers and reel base drives. The counter belt can also gatherup and prevent the takeup reel from working correctly, or fire the auto stop mechanism preventing it from playing, although that sounds to be ok in this case as the unit will FF and REW ok. The takeup drive is supplied by a different drive idler as it requires much lower and more controlled torque. This unit was always considered to be a great tape deck and is well worth a bit of attention for restoration. You can get a new belt kit for $19.00 from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
Teac a103 cassette deck. I want to know how much of this thing do I have to dismantle to replace the belts?? the online manuals ****!
It is not all that hard. You need to take the transport out of the chassis and then remove the screws required to get the motor mount and thrust plate off of the rear area of the flywheel. I have done them many times at Teac in the Chicago Factory Service. You need to get the right belt first. There may be more than one belt to replace in the unit such as one in the front near the counter. I can fix it but it might not be as cheap as you might think. I have been servicing Teac decks for 40 years so far.
Teac Tascam Repairs Skywave Tape Deck Repair Bensenville IL
Jan 19, 2014 | Audio Players & Recorders
Teak a1200 reel to reel tape deck
Getting a belt is easy but the replacement of only that part to fix the deck is only a dream. Older decks need all kinds of other work to make them right. I have been doing them now for 40 years and there are no short cuts if you want it fixed right. Also to get them to record correctly with the better tape of today they need record EQ modifications which I have been doing since Scotch 207 came out. There are now 4 1 mil tapes that are going to market. 1 from ATR, 2 from Pyral, 1 from Splicit.com called Capture.
Belts can be had from Marrs in Texas or Consolidated Electronics in Ohio. I don't mess with E bay belts as they only want your money and often times they are wrong. I change a lot of them that are oily looking and even the wrong size from customers that can not get their decks to work. They work well when I am done with them. I have been doing this business a long time and I was the guy at Teac in Arlington Heights. No amateurs here.
Apr 18, 2013 | Teac Audio Players & Recorders
I have a Teac A-1500 reel to reel tape recorder and need a drive belt for the capstan, Can you help me?
Contact: [email protected] He can supply drive belts for Teac reel to reel recorders and other manufacturers units.
Mar 31, 2011 | Teac Audio Players & Recorders
Instructions for Teac Tascam 32-2B belt replacement. I have had this Reel to Reel Tape Recorder for a number of years and the belts have now perished. I have purchased replacement belts on ebay but could...
Ebay is the worse place to get belts- why do I know this? Well, as a servicer I am constantly replacing belts that are from E bay when clients can not get their decks to work with those wrong belts. While the counter belt is not critical the capstan belts are in a dual capstan system. The 32-2B is a X10 derivative so it will need proper servicing to work well. I am in the Chicago area and work on decks all the time as Skywave Tape Deck Repair just google it.
Mar 19, 2011 | Teac Audio Players & Recorders
Where can I buy a Capstan drive belt for a Teac A-4010 tape recorder??
Go to a consumer electronics repair shop, preferably an old mom&pop op and they will have what you need. If not they can order it for you when they do stocking and save you shipping money from any internet company. I used to work at one is how I know. Have a good one
Aug 07, 2009 | Teac Audio Players & Recorders
Teac X-1000r broken drive belt
Gidday Chino
You can get a FRESH belt kit from here. Cost you $10 plus some post. There is a new pinch roller listed against this old girl also could be worth replacing at the same time when you service the deck.
regards
robotek
Aug 05, 2008 | Audio Players & Recorders
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
Mar 25, 2008 | Audio Players & Recorders
44 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
