Question about Dirt Devil M084600 Dynamite Bagless Upright Vacuum
D.d vaccum i have a dirt devil dynamite...i bought a new for it i put it on and not even 1 minute of using it the belt broke again!!!!i dont know whats going on do i have 2 put it on a certain way does it need grease or what!
    President:
  • 1,673 Answers
Did you check the brush roll, if the ends aren't turning freely, then it needs to be replaced also.
Posted on Mar 20, 2008
SOURCE:
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Belt drive keeps melting every belt we put on
usually that means something is stopping the brushes from spinning weather it is not greased well or just something still there I can't tell you but that is the broblem. You could try asking in a vac store/repair if they've had a fair amount of that model doing this and reccomomend a slightly different size .thickness belt to take up some slack
May 17, 2010 | Dirt Devil M084600 Dynamite Bagless...
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil- Brush not rotating on its own. No suction.
drive belt. take housing apart (draw a diagram so you can put it back together) take the broken belt to a vacuum repair shop to get the same one. mine cost 7$.
15 minutes work.
Jun 14, 2009 | Dirt Devil Featherlite Bagless Vacuum...
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Describe your Dirt Devil M084600 Dynamite
u all ready try taking botem off to getto it no luck ?
Feb 10, 2008 | Dirt Devil M084600 Dynamite Bagless...
Your roller won't turn. The belt is designed to break if anything threatens to keep the motor from turning. When you have the roller out, check the end caps to see if they rotate easily. If they do, then install a new belt being very careful that the belt is not pinched on the channel that it sits in. Once you have the belt installed, turn the roller by hand to make sure that there is no jamming or catching of anything. Install the plate and check the rotation again. Once you are satisfied that the roller turns easily, try the machine.
If the caps on the roller are jammed, as they will get from debris, hair and thread, etc., then you may have to replace the roller. The end caps on most of the Dirt Devils are carbon fibre and will break when you try to remove them.
Jan 30, 2008 | Dirt Devil M084600 Dynamite Bagless...
My vacuum is making a horrible noise!
I solved my own problem. I bought a new vacuum.
Aug 13, 2007 | Dirt Devil M084600 Dynamite Bagless...
Dirt Devil M084600 Dynamite Bagless Upright Vacuum Logo
139 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
