Question about Food Mixers
KITCHENAID K5-A STANDUP MIXER
Manual
  • roseannevivo Nov 30, 2008
    need manual for 5 qt kitchen aid mixer
  • ldhteh25
    ldhteh25 Sep 15, 2012
    My wife just found a K5-a in the thrift shop and amazingly low price. Ordering parts now.
  • 135 Answers
Hi. For a manual that supports your K5 mixer, goto www.mendingshed.com look for their Kitchenaid Service Manual. Download these files, they are very thorough and helpful.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Posted on Mar 24, 2009
    Scholar:
  • 104 Answers
Cannot find a K5-A model, must have complete model number, however here is a link to the Commercial 5 Series. You'll find the Use and Care Guide at the bottom of the page.
KitchenAid Commercial 5 Series
Posted on Mar 20, 2008
SOURCE:
Hobart Kitchenaid parts for mixer model K45
The WACEM (We Actually Collect Electric Mixers) web site has a downloadable PDF of the "K5-A, K45 Original Service Manual" in the "files" section.
This can help you figure out what has gone wrong with yours.
Jan 10, 2018 | KitchenAid Food Mixers
How do I identify and order the part I need fixed on my Kitchenaid K5?
It is called the Bowl support. It is part #4 on the diagram in the. Instruction manual.. I
Aug 09, 2014 | KitchenAid 5KSM5BER K5 Heavy Duty Mixer...
What model kitchenaid was made in december of 1973?
Is the brushed band around the head missing or worn off? The model is on that band. If it worn or missing in order to correctly answer your question I need more information. Is your mixer a tilt head or a bowl lift variety? Did you look on the bottom of the base for a serial number? Some models had them there. Can you describe the ceramic piece a little better? Many models shard the same internal parts and it might not be too difficult to locate that part.
Aug 03, 2014 | KitchenAid K45SS Classic Stand Mixer
Question: How do you put the string and spring wire clip back into the planetary assembly so that it won't interfere with the gears by coming loose?
I have repaired/reconditioned a number of K5-A mixers and have never encountered the parts you have described. They are not in the Service Manual. Try reassembling without those pieces.
Jul 24, 2014 | KitchenAid Food Mixers
What is wrong with a kitchenaid k5 mixer that won't turn on? There was a higher pitched sound from the motor and the next time it didn't turn on.
Consult the Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 13, 2014 | KitchenAid 32685 Mixer
Mixer doesn't work
There are a number of things to consider:
The round ceramic resistor is bad.
One or both brushes are worn out.
The armature and/or stator windings are bad.
A wire connection is no longer connected.
The on-off switch is bad.
The control board has a fault.
Finding many replacement parts for for a K5-A is difficult but not impossible. The folks at WACEM may be able to help.
If you join WACEM (We Actually Collect Electric Mixers), you can find (under Files) the K5-A original service manual.
If the motor is working but the beater does not go round, it is most likely that the sacrificial worm follower gear has given out. These gears are essentially unchanged to the present day and are readily available. The Service Manual shows how to change it.
https://groups.yahoo.com/neo/groups/WACEM/info
May 10, 2014 | KitchenAid Food Mixers
Kitchenaid K5-A ...need wiring schematic
RE: Wiring for KitchenAid K5-A (before the solid-state control).
See: http://groups.yahoo.com/group/WACEM/files/K5-A%20Old%20k45%20Wiring/
and: http://groups.yahoo.com/group/WACEM/photos/album/914415457/pic/list
Aug 07, 2012 | KitchenAid Food Mixers
My wife has a K5A mixer from the '70's that she loves. While I was checking the brushes, I over-tightened the brush cap and broke the threaded part it screws into. Can I get a new part?
The Brush holder caps / covers for the K5 series whether Hobart or Kitchenaid by Whirlpool (after 1986 when Whirlpool bought Kitchenaid from Hobart) will fit the K5-A they just wont be flush like the older Hobart caps. They come in black or white.
Jan 10, 2012 | KitchenAid K5SS Heavy Duty Commercial...
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Apr 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
2,510 people viewed this question
Top Food Mixers Experts
Bruce Showalter
Marvin
Marvin
Ross Keen
Are you a Food Mixer Expert? Answer questions, earn points and help others
