Question about GE JVM1440 Microwave Oven
Mirowave not heating where is magatron located
  1. jvm1640wb004
  • Anonymous Apr 29, 2009
    will not heat
  • Anonymous May 07, 2009
    How do you install the replacement magnetron?
    Mike
  • 6,993 Answers
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
If you cannot perform the above task yourself, ask a family or friend that has the ability to assist you or have a certified and experienced appliance repair technician examine and replace your magnetron. This task is much too dangerous for the average layman to perform on his own.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Regards.
Posted on Jan 05, 2012
Microwave ovens don't use heat to cook with... they use microwaves. Heat generated by the internal components is the same as heat generated by the motor in your car. It's a waste product of work. The best test for a microwave oven is to put a half cup of cold water in and run the set for atleast 30 secs.. If the water is not hot or atleast very warm, then the sets not working.
Posted on Sep 07, 2008
Why mirowave je2160f01 doesnt heat the food
This is usually caused from a bad magnetron. The door interlock switches couls be bad or the high voltage diode could be bad.
Aug 24, 2014 | GE SpaceMaker Microwave Ovens
Loud and not heating
you have a bad magatron... eather it's short or ground.. out of warranty ? if so drop it off at scrap yard.
Apr 06, 2014 | Whirlpool MH1150XMQ Microwave Oven
Microwave is not heating. What could be wrong?
there is a low and high heat cencor check them if thats not it it will be the magatron
Mar 31, 2013 | Microwave Ovens
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
Amana microwave rfs12sw2a Put in new magatron worked for 3weeks Now will not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 29, 2011 | Amana Microwave Ovens
I have a GE SpacemakerXL microwave oven - Model JVM1640WB004, S/NTZ979368S. It is no longer heating. The lights, fan and rotating tray are still working. Will this repair be so expensive that it would be...
When there is no heat, but everything else seems to work, it means the magnetron circuit has failed. The magetron is the part the generates the microwaves that heat the food. When it fails, it makes a loud buzzing sound. The replacement part can cost as much as a new oven, so it not worth fixing. Get yourself a new oven.
Feb 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The oven is not heating up but everything else is working.What is the problem
More than likely the Magnatron has gone bad. this is the device that atcually creates the micro waves that create the heat. They go bad after several years of use. They can be replaced but mirowave ovens are generally cheap enough to get a new on instead of repairing the old one.
Nov 27, 2010 | Belling Microwave Ovens
GE JVM1440 Microwave Oven Logo
282 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
