Question about Whirlpool SF378LEPS Stainless Steel Gas Kitchen Range
I'm looking for a gas range with some bells and whisles but I run on solar only so it can't use a glow bar ignition system
I've herd of a direct spark ignition system by whirlpool but cant identify any models in Canada. Please help
    President:
  • Whirlpool Master
  • 2,651 Answers
"Ingles" is the canadian name brand for whirlpool, if thatsany help to you. I would check with the local appliance sales guy, the smaller local guy usually more knowledgeable then the big impersonable dealers
Posted on Mar 20, 2008
Oven igniter will not spark
most oven igniters dont spark at all. they have "glow bars" that are connected to a gas safety valve. the bar will glow red hot and once it pulls enough amps it will tell the gas valve in the oven to open up and when the gas hits the hot glow bar it will ignite. the glow bar can still glow red and the valve wont open. it is still a bad glow bar because it's not drawing enough amps. if you replace this part yourself do not touch the actual "element" with you hands because it will cause it to break the first time you use it. you can only touch the base.
Mar 12, 2014 | Kitchen Ranges
Viking oven broiler will not ignite
Your gas valve would be my first guess. Is this broiler (and bake ) lit with a glow coil or spark probe that goes (goes click, click, to light)??
If spark probe, you will have to replace either gas valve or spark board.
If glow bar lights the broil but does not glow, then replace glow coil.
Oct 18, 2013 | Dynasty DGRSC 48-6G Gas Kitchen Range
After ten minutes the dryer stops and the filter light is lit
The glow-bar system sends electric current through a heating type of element until it glows hot enough to light the gas (this is used on most older style dryers) An I.R. sensor (infrared sensor) determines when the glow-bar is hot enough to light the gas, it then sends a signal to the gas valve to turn on.
To test this system, open the front cover where the burners are; start the dryer in the heat cycle; you should see the glow bar getting red hot (the glow-bar sits inside the burner box just above the burner tubes - there are two types; a round one that has spirals, and a flat one that looks like half of a coat hanger except smaller. If you have a hard time identifying them go look at the pictures of them in the store section) If nothing glows you will need to take a voltage reading across the glow-bar leads (there are 2) as you first start the dryer. No voltage means it's something else. Voltage means replace the bar (a replacement glow-bar should be kept in stock).
If the glow-bar lights and does not go off then the I.R. Sensor has failed. (I usually replace the glow-bar along with the I.R. sensor because one will take the other out, and it's just good maint. procedure to do as such.)
If the glow-bar lights for about a minute then goes off and you do not hear a click sound come from the gas valve (this click sound is the coil in the gas valve opening) then it's probably a bad gas valve coil (see below). If the glow-bar lights, then turns off (in about a minute) and the gas valve clicks on (and you can hear and/or smell that the gas valve is open) the burner tube holes are plugged and/or the glow-bar needs to be adjusted closer to the burner tube. To clean the burner tubes, you can either shoot compressed air into them, or remove them and run water through them. If it's an older dryer it's best to remove them and run water through them so as to get all the compressed lint completely out.
If you have a spark ignition (looks like a spark plug wire from a car...in fact it is.) The way that this system works is, instead of lighting the gas with a glow-bar, it lights it with a spark. To test the system, open the burner cover, turn the dryer on in heat mode, you should hear the gas valve click, and the spark igniter sparking, (in fact, it may even light the gas, but then goes right back off.) If this is the case then most likely the ignition cable is bad. Most people think that just because they can hear the spark, and see the gas light that the cable is OK, however, the ignition module sends a small amount of voltage the opposite direction through ground, through the fire, and through the high voltage ignition cable back to the ignition unit to let it know that the gas has lit. If the ignition cable has a even the slightest crack in the carbon core cable; that small amount of voltage cannot jump that crack like the higher voltage.... So replace the cable. (if it's a weekend and your faced with a downed dryer; either buy one from an auto parts store, or borrow one from someone's car...) The other thing that it may be is plugged burner tubes, if it looks like there is a lot of lint in the burner compartment you may want to try blowing out the burner tubes or removing them and rinsing them out with water.
Check circuit breaker. If it's a 220V machine be sure you have all legs of your power.
Check your neutral leads (I can't tell you how many times I've seen wire nuts come loose...) I've also had alot of power cords (especially 120V) go bad; check them.
Check control fuses, there's usually more than one. Sometimes they put them in the computer control board.
If there is a transformer in the main circuit (There may be two-one for the heat circuit, the other for the control circuit) be sure to make sure you have incoming and out going voltage according to the schematic voltage or it should say on the transformer.
Make sure door switch is adjusted properly or hasn't failed.
Check belt or chain.
Check the conduit going into the motor, sometimes older motors get hot and the mount fails causing them to rotate in their craddle and pulling out the conduit and wires. After repairing the wires you can run a large hose clamp around the motor so as to secure it. This will keep you going long enough until it's replaced.
If the dryer works only while you hold the start button on, it means the start circuit in the motor has failed (120V - 220V single phase system) I've seen people put tape over the button, however this should only be a temp. fix...replace the motor. For a three phase system, it's most likely the start relay is bad.
Be sure to check the main start contactor, these seem to fail quite frequently, they are usually located behind the dryer in the rear control panel.
Dec 21, 2010 | Bosch Dryers
I have proble with whirlpool gas range SF265lxtq When I tried to use the oven, I setup the oven by the keypad, but the oven does not get hot, and i did not smell gas. What should I do ?
Your Direct Spark Ignition System contains a
Gas Distribution Valve and a Direct Spark Ignition
(DSI) Control that interfaces with the
Electronic Oven Control, and spark electrodes.
This provides the direct spark ignition and gas
distribution for Whirlpool self-cleaning gas freestanding
ranges. You must familiarize yourself with this system
before attempting any repair. Look through this service
repair manual for direct spark HERE
Mar 01, 2010 | Whirlpool SF265LXT (Gas ) Kitchen Range
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Greetings! We have a 20'' Magic Chef gas range model CGL1100ADW. Really what I'd like to do is get rid of the glow bar and have it light like the pilotless ignition types. The reason? Because it's in a...
    The glow bar acts like a resistor and has to draw the correct current to activate the gas valve. What you want to do is redesigne the appliance, something that is not recommended and cannot be advised for liability reasons. There are appliances already designed and approved for use in the application you desire. For your safety sake, replace the appliance.
    Eric
    Dec 07, 2009 | Kitchen Ranges
    How do I utilize the self cleaning part? Do I just press ''clean
    1. After self cleaning the range the door won't open
    2. Amana gas range conversion from NG to propane
    3. A tip on cleaning the surface grates
    4. Checking an common oven temp sensor
    5. Checking an common oven temp sensor: What does an oven temp sensor look like?
    6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
    7. GE gas range conversion from NG to propane
    8. How to change the oven temp on some common electronic controlled ovens
    9. How to re-light a surface or oven pilot light
    10. How to change a common oven glow igniter coil
    11. How a common gas valve works - click here.
    12. How Ranges, Ovens, and Stoves Work
    13. Help for storing an appliance
    14. Important Disclaimer
    15. Installing a gas flex line connector
    16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
    17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
    18. My gas range flames die when I turn on more than one thing at a time
    19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
    20. My surface burners keep "clicking" even after the burner is light
    21. Oven door and door hinge help
    22. Oven temp sensor - how to change helps
    23. Repair tips and information on surface burner spark modules and igniters
    24. Some "how to set the self clean" on my range
    25. Stainless Steel Cleaning
    26. Surface burners wont work
    27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
    28. Test for F1 fault code
    29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
    30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
    31. Whirlpool Direct Spark Ignition (DSI)
    32. Yes, your glow bar igniter can glow red and still be bad!!
    Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
    GE Profile Gas Range oven light doesn't work even after changing
    Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    Magic Chef Gas Range
    Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
    Jul 29, 2007 | Magic Chef CGR1110 Gas Kitchen Range
    Open Questions:
    Whirlpool SF378LEPS Stainless Steel Gas Kitchen Range Logo
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
