Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Machine wont work at all
All the lights are on and everthing looks ok when i push the start i can hear a humm but that is all no water no count down on the meter nothing just sits there.
  • FrankenS Mar 27, 2008
    Had the same problem. The service guy said the control panel and and the pump were fried. It can take up to two weeks to get parts.
    President:
  • Whirlpool Master
  • 2,651 Answers
This can be a tricky machine, but lets see what we can do. First thing youll want to do is insert a putty knife in between the main top and the front of machine, perhaps 3 nches in on either side and "pop" the clips holding down the lid, HOLDING the lid assy (cause its spring loaded nad sometimes glass) tilt he main top back, across the front wall of the right hand side wall you should find acheatsheet/ tech sheet for this unit explaining all the different tests and a pretty good troubleshooter as well
Posted on Mar 20, 2008
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
My 1996 dodge neon wont start. I was told it was the starter because it would start after we banged on it with a hammer. When I parked the car it wouldn't start unless i push start it or banged on the...
The starter relay or starter solenoid would be my guess, but I am wondering what the gears on the old starter looked like. If they were in really bad shape (deformation or chunks missing) you may need to replace the flywheel.
Dec 24, 2009 | 2005 Dodge Neon
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
Dryer does not run when you push start
Is this a Maytag? What brand and model do you have?
Sep 23, 2009 | Dryers
My kenmore 80 top load series wont rinse top load wont rinse
drain pump is trying to drain. maybe have something in pump
Jun 22, 2009 | Washing Machines
Ge side by side is making ice but water dispenser stopped working
check all hose connections and if those are good push your butto for water and see if it humms or clicks.if it humms the water valve might have gone bad or their is not a connection in the hose some where.if you dont hear it click then it is broke behind face.check all components to water side for break or bad switch.
Mar 08, 2009 | GE Profile PSI23NCR Side by Side...
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
96 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
