Tip & How-To about Computers & Internet
Method One
If you share your computer with other people, you can maintain separate user accounts for each person who uses the computer. This is useful especially if each user has different tastes in music; users can maintain separate, personalized iTunes music libraries and can customize their iPods accordingly.
Mac OS X users:
Learn how to set up additional user accounts.
Windows users:
Look in your computer's Help documentation to learn how to set up additional user accounts. To locate this information:
Click the Start Menu, and then click Help or Help and Support.
Enter "new user" in the Search field.
Press Return.
If you create multiple user accounts on one computer but want the same music to be available in iTunes for all users, see iTunes: How to share music between different accounts on a single computer.
Method Two
You may use multiple iPods on a computer without the need to create multiple user accounts. To do this, you can set iTunes to update each iPod with only certain playlists. This method allows you to put all your music on, say, your iPod and keep your iPod shuffle updated with only your workout music. Here's how to do this with iTunes 9:
Create new iTunes playlists that contain all the music that you want to sync to each iPod.
Learn how to Sync your iPod (read the iPod Tutorial Steps section below the video).
Note: iTunes for Windows does not support syncing multiple iPod devices at the same time.
Method Three
Create a separate iTunes library for each iPod. Note: It is important that you make a new iTunes Library file. Do not just make a copy of your existing iTunes Library file. If iTunes is open, quit it.
Mac users: Hold down the Option key while you open iTunes.
Windows users: Hold down the Shift key while you open iTunes.
In the dialog that appears, click Create Library.
Name and save the alternate library file. iTunes opens with your brand new library file.
Open iTunes Preferences. Choose iTunes > Preferences (Mac) or Edit > Preferences (Windows).
Click the Advanced tab.
Deselect the "Copy files to iTunes Media folder when adding to library" checkbox if it is already selected and click OK. This will prevent iTunes from creating duplicates of your existing media files in the new library folder.
Add the specific media files you want on your iPod to iTunes either by dragging them into iTunes or choosing File > Add to Library (Mac) or File > Add File to Library or Add Folder to Library (Windows).
Once you have the iTunes Library just how you want it, connect and sync your iPod.
Once the sync is complete, quit iTunes.
Click Choose library.
Choose your original iTunes Library and click Choose (Mac Users) or Open (Windows Users). You can now switch back and forth between the different libraries for different iPods.
If your Windows PC has is equipped with an Ethernet port, you can
connect your PC and Macintosh using an Ethernet cable. By doing this,
you are creating a small local network, consisting of just the two
computers. Set up your Windows PC by turning on File Sharing. Refer to
the instructions that came with your Windows PC if you're not sure how
to do this.
To locate and connect to the Windows
computer, you can use the sidebar in a Finder window. You need to know
the workgroup name for the computer and the network name (called the
"computer name") for the computer. To connect to the computer, you also
need a user name and password and the name of the shared folder you want
to access. If you don't have this information, contact the person who
owns the computer or your network administrator.
If you cannot locate the Windows
computer in the Network browser, you may be able to connect to it using
the Connect To Server dialog in the Finder.
Make sure the Internet Connection
Firewall is turned off, or if it's on make sure TCP port 445 is open to
allow sharing connections.
To connect you Mac and Windows computers:
In the Finder, choose Go > "Connect to Server."
Type the network address for the computer in the Server Address text box using one of these formats:
smb://DNSname/sharename
smb://IPaddress/sharename
Follow the onscreen instructions to type the workgroup name and a user
name and password, and choose the shared folder you want to access.
