Question about Audiovox FPE1078 7.8 in. TV/DVD Combo
Continuous Channel Searching & Power Button Issues
I'm having several problems with my tv. First, as of today I can only turn it on using the remote, not the power button on the tv itself. When I do turn it on, it goes automatically into DVD mode, but when I switch the mode to tv, it goes through a blue screen channel search, climbing into the 100s, briefly flashing a picture on channel 2, then goes back into the search endlessly. I can only turn off the tv at that point by unplugging it. Is it the tv? My cable? Please help!
  • Anonymous Mar 25, 2014
    Flashing red indicator light can't turn on the tv
  • 979 Answers
What source are you using? If cable, you should only be able to pickup channel 3 or 4 if you're using the box. If there is no antenna, that would be the only other answer if the set checks out...accordianman
Posted on Mar 21, 2008
How do i enter tv code for the rc66rx remote?
This is backwards. Codes are ion the remote.
Nov 10, 2016 | Televison & Video
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Nov 08, 2009 | Radio Shack (15-2147) Remote Control
Rcr311w need help and advice on programming
WHAT BRAND OF TV ARE YOU TRYING TO PROGRAM
Jun 03, 2009 | RCA Universal Remote Control
Need remote for sylavania tv model srt 2113
I bought a "Universal Consolidator" today for my own SRT2113, and it works like a dream. It's the 15 dollar universal remote you always wanted. Its menu, channel searching, volume, and, yes, the infamous GAME MODE even works (use the input button)!
Mar 10, 2009 | Zenith ZEN450 Remote Control
Remote problems
This is the preferred method of code searching our technicians use.
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
I hope this helps you and thanks for using Fix Ya.
Dec 01, 2008 | DISH Network IR Remote Control
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
Aug 22, 2008 | Radio Shack 15-2142 Remote Control
How to set codes on my px-rc1 remote
Hey finally I found myself how to set the code... I have a PX-RC1 kind a noname remote at XScargo anyway...
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED shoould stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. THen press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.. I guess if it doesn't work good, go further onto the code with the +CHANNEL BUTTON (better count it in case you go too far, for myself I went too far and tried to use the -BUTTON and didn't work)
GOOD LUCK GUYS,
May 18, 2008 | Universal Remote Control MX-500 LCD Remote...
Still having issues
Please refresh my memory; What was it that I had suggested originally?
May 08, 2008 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Jan 14, 2008 | Televison & Video
Audiovox FPE1078 7.8 in. TV/DVD Combo Logo
117 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
