Question about Canon BJC S600 InkJet Printer
Error 5100 for canon s600 bubblejet printer
I have lost my manual & this service error 5100 is coming up. When it does print it is putting squares and dragging ink all over the page, and making a great big mess. I have done deep print head cleaning and nozzle checks etc all morning trying to see if that is the prob , but to no avail. Can you help :)
  • GBITt Aug 18, 2008
    I do have the same problem. I do get the 5100 error on my canon S600!
    We can help?
  • 412 Answers
Try these points ----
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
SERVICE ERROR 5100 CANON I560 PRINTER HOW DO i FIX THIS?
Hi There
You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 06, 2010 | Canon BubbleJet i560 InkJet Printer
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Solution 2:
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
Canon S600 bubblejet priner won't print color
In all likelihood, the nozzles in the printhead are blocked. The printhead is the carrier that holds the tanks. Remove the printhead and remove the tanks from the printhead. Flush the printhead THOROUGHLY with hot running water. You can also **** on the color discharge area (square and the black discharge area (rectangular) on the bottom to draw warm watr through the nozzles to further clean them. Dry the prinhead thoroughly, reinsert your tanks and reinsert the printhead in the printer. I then do a "nozzle check" to refill the passages in the printhead and get things flowing agan.
Oct 25, 2008 | Canon BJC S600 InkJet Printer
Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
Canon s200sp printing problems
I have lost the disc to set up the connection from the computer to the printer. could you please email me the information.
Feb 07, 2008 | Canon BubbleJet i560 InkJet Printer
Error 5100
where is the best place to get this repaired>
Nov 06, 2007 | Canon PIXMA iP90 Mobile Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon BJC S600 InkJet Printer Logo
456 people viewed this question
old marine
old marine
