Question about Frost Inglis 17.6 Cu. Ft. -Free Top-Mount Refrigerator - Silver - IT18SKXRD
Inglis Refrigerator- Complete Failure
I come home the other night and everything in the freezer was thawed and in the fridge it was warm. I unplugged the fridge and used a different plug, to no avail. When i unplugged it something did turn off, sounds like the fan. But other then that it is not working?? What do i do?? The manual has no questions/solutions for this. Can someone help me??
  • 1 more comment
  • DawnDL Jul 13, 2008
    Ours is not a side by side. The fan currently is on (for a bit it was not) and it is not keeping the food frozen in the freezer, nor is it keeping the food cold in the refrigerator itself. We have cleaned everything out, including the fan area, & moved it 2 ft away from the wall, its still not working correctly. It is only 3 years old.
  • akeveridge Apr 17, 2009
    my whirlpool I nglis runs warm..I unplugged it and replugged it in..the compressor..runs..still warm..any ideas?
    Thanks
  • Anonymous Mar 30, 2014
    Vent below freezer in fridge is producing water, is something plugged?
  • 52 Answers
Do you hear the compressor running at all???
Posted on Mar 20, 2008
Is it a side by side?
Pull the fridge out.. remove the cardboard bottom cover and inspect the fan next to the compressor to ensure that it is working. Sometimes it can be blocked by the false bottom of the fridge which is made of cardboard and tends to buckle in the heat.
If the fan is not working and there are no obstructions, you will need to replace it or have a tech check it for power.
Check your plug behind the fridge with a light if you don't have Multi-meter.
Checking the back fan will take you just a few minutes and can save you a lot of grief.
GPS.
Posted on Jul 04, 2008
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Coils freeze up in freezer and fridge gets warm
You have to completly thaw out the the freezer and dry off all moisture with paper towels then turn back on be sure to wipe the rubber seals down so no moisture is pulled out of the air between the seals of the door and cabnet.
Oct 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Buyers Beware!
go to sears
Aug 14, 2009 | Refrigerators
My Inglis Refrigerator doesn't make ice anymore,
Had the same problem. Chances are that the water has frozen in the supply tube, not allowing water into the maker. you will need to unplug and thaw out your fridge entirely to thaw it out. I used a hair dryer pointed at the filler tube to defrost it.
Jun 23, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Everything in My Freezer is Melting and Fridge is getting warm!
find another place for all of your food because you may need to call a service company.
possible causes: stuck in defrost (if nothing is running) bad compressor (if fans are still running) freon problem if everything is still running
Jun 28, 2008 | Jenn-Air JCD2389G Side by Side...
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
793 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
Charles T Nevin
Charles T Nevin
Mike
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
