Question about RCA Lyra RD1071 MP3 Player
3 yr old Lyra 1071a
I use this only when I walk on my treadmill, about once a week. Today it just would not turn on. I put in two different brand new batteries. Still nothing, I really like it for my workout. I have the music so that it takes me to the level I need at a rate that is good for me. I am 60. So no spring chicken.
Thanks
Sherry
  • joceylou Feb 07, 2009
    I have the same exact issue!! I don't want to "trash" this player but cannot find any information on how to get started.
4 Suggested Answers
  • 3 Answers
SOURCE: Unit displays "RCA" when turned on, nothing else
Update the firmware off the RCA/Thompson site. Likely that the current firmware is damaged.
Posted on Sep 09, 2007
SOURCE: Music Files for RCA Lyra 1080
I have upgraded my RCA Lyra 1080 and show music files on the Lyra Window in my pc, but when I attempt to play music on the Lyra it says "no music files."
Posted on Oct 01, 2008
joe7379
  • 93 Answers
SOURCE: RCA lyra 115a 5G mp3 player
you are right you need to change the format back to MP3. Do you have the orginal songs in MP3 and then converted then to MP4? If not try http://www.mp4-mp3.net/ you will need to take all the songs from your ipod and put them in a local folder on your pc, then convert them and then move them to your mp3 player. hope this works for you.
Joe
Posted on May 19, 2009
Unit doesnt cut on.
proform 730 performance treadmill was working just fine..son left for Air Force in May last yr.tried to use it today and electricals wont turn on..
Jul 05, 2012 | Proform 730 Folding Treadmill Model...
Problem with pro.form treadmill Model No. 831.299212 Serial No. M30377474
The problem is that the belt is old and is overheating your motor. That model is way too old to put that kind of money into. Buy a new machine.
Oct 20, 2017 | Exercise & Fitness
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
Hi, our proform 790 tr treadmill is aorund six years old and the walking belt and height motor seem to be going. Is it worth replacing these and is it fairly straightforward?
Changing a walking belt takes about an hour for someone who has done it before. Check the walking deck for scratches, damage as well. Often times if the belt is worn out, the deck needs to be replaced as well. Belts vary in price depending on the make and model of treadmill. Parts can be ordered by calling the number found on the model number sticker on the treadmill. There are 10 different machines with the 790t model name. To get the correct parts find the actual model number (will start with "H"). The parts come with replacement instructions.
Belt $105 Deck $190
As for the incline motor, it is very rare to change that part. It may just require calibration. Start the machine . Press incline up and hold, remove the safety key. Now reinsert the safety key. The machine should rise to full incline then back down to minimum. Once the cycle is complete, the treadmill should work normally. If the incline sensor is defective, the motor will have to be replaced. Incline motor $150.
Feb 26, 2011 | Proform 790T Treadmill
We just bought a gently used Lifestyler Expanse 1500 treadmill today; it turns on & runs nice & smoothly...until we walk on it. When we start walking on it, it wants to slow down & we feel like...
From the manual: Troubleshooting
Symptom: The walking belt slows when walked on
a. If an extension cord is needed, use only a 14-gauge general purpose cord of five feet or less in length.
b. If the walking belt is over-tightened, the treadmill performance may decrease and the walking belt may be permanently damaged. Remove the safety key and UNPLUG the power cord. Using the 3/16" allen wrench, turn both rear roller adjustment bolts counterclockwise. 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each side of the walking belt 3-4 inches off the walking platform. The center of the walking belt should just touch the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert safety key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
c. If problem persists, contact customer service.
Sep 17, 2017 | RTO Exercise & Fitness
Treadmill maintence
Here is a typical guide for maintenance their may be a slight variation from different manufacturers all in all the same.
NOTE: To prevent electrical shock, be certain the treadmill is turned off and unplugged from the electrical outlet before performing any cleaning or routine maintenance. TREADBELT LUBRICATION For average use of your treadmill, factory recommends you lubricate under the treadbelt once per year. For heavy use, which is more than 10 hours per week, factory recommendation is lubricating every six months. . LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes. CLEANING DAILY: Perspiration should be wiped from the control console and treadmill surfaces after your workout. CLEANING WEEKLY: You should wipe down your treadmill once a week with a water dampened, soft cloth. Be careful not to get excessive moisture between the edge of the digital display panel and the console, as this might create an electrical hazard or cause the electronics to fail. IMPORTANT: DO NOT CLEAN OR WIPE THE TOP OF THE DECK UNDER THE CENTER OF THE RUNNING BELT. MONTHLY: Clean dust and dirt that might accumulate under and behind your treadmill once a month. Small rubber particles from the soles of walking shoes will accumulate alongside the belt and also behind the unit
Apr 27, 2010 | Exercise & Fitness
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
I have an Image 929- 15 yrs old. Has been working great. I have changed the drive motor belt before and it worked fine. Lately the belt is loose with a decent amount of play. I have tried to tighten...
I would first watch the unit while walking and visably see if the drive belt is slipping or the walking belt is. If neither one seems slipping, it is possible that the torque control on the motor control board is not correct
Gerritt
Serving the Twin Cities
Mar 06, 2009 | Proform Crosswalk 500 Treadmill
RCA Lyra RD1071 MP3 Player Logo
42 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
