Gateway FPD1960  19 in. Flat Panel LCD Monitor
Problem for Gateway FPD1960 (Silver) 19 in. Flat Panel LCD Monitor
Monitor will not turn on- was working fine a week ago!
By DonExodus on Mar 20, 2008
Thanks for your help guys.
It all started a week ago- I could not get my monitor to turn on when I arrived home. I typically turn off my monitor, go to school / bed, and leave my computer running. I would move my mouse to initiate it out of whatever sleep/screensaver mode it was in (not hibernating), and it would not turn on. It woulf fizzle, I would see gray vertical lines, then it would just go out. The orange 'power connected' light would not even turn on, which is supposed to be on, regardless of computer connection, as long as the monitor is plugged in.
Early on, when I would try and revive and my monitor would go out, I would wait an hour or so, try and turn it back on, and it would again go through the gray / black lines, and MAY (50/50) kick on and work normally.
Now its at the point where I cant get it to turn on at all, no orange standby light, no power whatsoever, nothing. My CPU is fine, the power cord is fine, my monitor just fails.
Gateway is worthless, they dont want to do anything about it. How can I get this fixed?
Comments:
Mar 22, 2008
- Actually, I took it to a comp reply place. The 450uf 100V capacitor busted, its like a $5 part, Im just going to get a new one, solder it, and hope for the best.
But yea, its ********
Same Problem
Mar 21, 2008
-   I have only had my Gateway Monitor a little over a year and now it will not turn on. The orange stand-by light will not come on either. Screen freezes and turns gray. I payed over $300.00 dollars on this monitor. It should work longer than a year before before problems start to happen. If I send it to a Gateway Tech. will they fix it?-   Guest
Best Solution
posted on Mar 26, 2008
Helpful)
tantong
Rank: Guru
Rating: 86%, 185 votes
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went gray or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Was this helpful?
Yes
No
Popular Solutions for Gateway FPD1960 19 in. Flat
Questions and Unsolved Problems for Gateway FPD1960 19 in. Flat
Do you recommend Gateway FPD1960 (Silver) 19 in. Flat Panel LCD Monitor?
Answer
Answer
Is this monitor compatible with hdcp, because I want to play my ps3 on it?
Answer
Answer
There is a big black border at the top, bottom, and left of my screen, so my desktop, offline, and... (More)
Answer
my fpd1960 comes on and within seconds the picture goes away and the power button changes from blue... (More)
Answer
The Main Menu keeps flashing on and off in the bottom right corner of the screen. I have turned it... (More)
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
