FixYa.com
Tags:
NEC CONTROL PANEL BOARD
IC7-G - problem with build in Intel nec connection
By pandamama - usenet poster
Have an IC7-G running XP Pro. Only problem is I can't connect to NW5
server. Installed drivers from abit cdrom for Intel and all seems to
have gone correctly (?). Cat 5 cable connected to 10/100 switch which
shows it has a connection.
From Control panel/networks, it shows a modem connection and under Lan
it shows 2 1394 connections. I can't seem to locate the Intel
connection. When I open the Intel Pro Connections icon from Control
panel, it doesn't show anything there, I tryed reinstalling the driver
but got the same results. Even tryed to ping 127.0.0.0.
I  tried a find new hardware and it didn't find the Intel stuff at
all.
Any ideas where to go from here?????
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On Mon, 16 Feb 2004 13:43:25 -0500, "TomG" <tgeery-NOSP @cox.net>
wrote:
Wow, thanks for all kicking in on this. Tom, I have tried removing the
firewire, checked the bios to make sure 'lan on board' is enabled,
Rebooted and got only the firewire reinstalled. only periferals are
the pic vedio and Creative sound. Sys is running Win XP Pro w/ a 3gb
processor, 1 gb mem and to Sata drives.
Would I be better off just geytting a PCI 10/100/1000 NIC???
I also checked support from where I bought the board, and they
suggested to RMA the board as they thought RJ45 bad.
IF I do rma the board, how do I get the new one to recognize the SATA
Raid 1 drives???
I understand that if it is RMA'd, I get a 90 day warrenty back
Thanks
Stephen
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
Oh Well ...
Some open 'doors' offer opportunity ...
some not.
Hiest by my own Petard ...
try again.
;_(
Qed.
Solution #3
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
oh, MAN!  that was baaaaaaaad!
Thomas Geery
Network+ certified
ftp://geerynet.d2g.com
ftp://68.98.180.8  Abit Mirror <-----  Cable modem IP
This IP is dynamic so it *could* change!...
over 120,000  FTP users served!
Solution #4
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
Yeahhh ... you aughta!!
I'd hafta call that getting "Heaped" upon ...
and not "moi", of all peeps.
Totally missed that "door" ...
good one Dion.
:_0
Qed.
Solution #5
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
er, my bad, for sure.  I did not catch that.  apologies all around.
Thomas Geery
Network+ certified
"Dion L Heap" <NoS @ThankYou.Com> wrote in message
Solution #6
Not Rated (0)
LiZzIe
Rating: 0%, 0 votes
Errrm, Tom, don't tell me you didn't read the part in the thread where I
wrote :-
Are you not getting enough sheep? <typo?> should be "sleep" ;o)
regards,
Dion L Heap
www.thetophouse.com
Solution #7
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
Dion,
This board has one Firewire controller and if he has an Audigy installed
(for example) then there will be a Firewire controller on that card as well.
Just a thought...
Thomas Geery
Network+ certified
Solution #8
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
1394 IS firewire, but if you are showing 2 when you only have 1 then
something is wrong somewhere which is what I was trying to say. Did you read
the replies properly?
regards,
Dion L Heap
www.thetophouse.com
Solution #9
Not Rated (0)
Brad
Rating: 0%, 0 votes
you should see the Intel Gigabit Ethernet adapter in addition to the 1394
adapters.  you either do not have it enabled in the bios or there is a
device that does not have a driver installed that is showing in device
manager.
one thing to be aware of is that in my experience, the bios menu options for
some devices, including specifically the onboard NIC, can disappear from the
bios settings screens.  clearing the CMOS with the jumper appears to correct
this problem.
Thomas Geery
Network+ certified
Solution #10
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
On Thu, 12 Feb 2004 11:48:47 -0000, "Dion L Heap"
I was under the impression from the MB book that I should see Intel
P?ro 1000 CT. If I click on the card icon in the toolbar, it only
shows an empty folder named Network. I thought the 2 instances of the
1394 was for firewire not ethernet.
SER
Solution #11
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
That's the one I was talking about, you should only be showing 2 1394
adapters if you have the one on the board enabled and if you have one on a
add in board such as an audigy card etc. As an aside, you have made sure
it's enabled in the bios haven't you?  If so then yes, I would uninstall the
2 instances of 1394 you have listed and reboot and see what happens.
regards,
Dion L Heap
www.thetophouse.com
Solution #12
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
On Wed, 11 Feb 2004 02:30:23 -0000, "Dion L Heap"
This is the built in lan connection on the MB,  would that make any
difference??
Solution #13
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
Thanks, I'll try it.....
Solution #14
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
Try uninstalling everything listed under "network adapters" in dev manager
and doing a reboot, the Intel should show up as "Intel(R)PRO/1000 CT Network
Connection"
regards,
Dion L Heap
www.thetophouse.com
Can you Help with these System Cooling problems?
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
System Cooling
Warning light.
Electronic fault indicator... Answer This...
System Cooling
Peoplesoft
There are how many ways for... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
