Wirlpool washer Water won't drain
  • deevanah May 13, 2008
    I have the same problem but it is a top load. and it just dies before going to rinse cycle. Where do I find the lower access panel to remove the pump cover to empty the "button trap" of debris? Please note my washer and dryer is one on top of the other small enough to fit into the closet.
    try lifting and closing the lid and just before it clotop load or front load??? if top load, does it appear to be trying to drain??? or does it just die before going to rinse cycle??? if so sounds like you have a bad lid switch try lifting and closing the lid and just before it closes do you hear a "clicking noise"..You should and if you dont you have a bad lid switch......... if its a front loader i would assume htat when trying to drain out you just hear faint humming noise and no action, if thats the case sounds like something is stuck inside the pump assy. you would need to remove the lower access panel and remove the pump cover to empty the "button trap" of debris.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Top load or front load??? if top load, does it appear to be trying to drain??? or does it just die before going to rinse cycle??? if so sounds like you have a bad lid switch try lifting and closing the lid and just before it closes do you hear a "clicking noise"..You should and if you dont you have a bad lid switch......... if its a front loader i would assume htat when trying to drain out you just hear faint humming noise and no action, if thats the case sounds like something is stuck inside the pump assy. you would need to remove the lower access panel and remove the pump cover to empty the "button trap" of debris.
Posted on Mar 20, 2008
Sounds like the lid switch.
Disconnect everything, power first. Keep the drain hose above the top of the washer if the bucket’s full of water. If there are clothes in it, remove them to a water-tight location (like a cooler or something).
Put the unit on an appliance dolly and get it onto the driveway before removing the drain hose from the rear of the unit. Water will gush out for a while here.
Unscrew the two hex bolts at the top of the unit that attach the plastic tabs to the console. Unscrew the screws in the end caps that attach it to the top of the cabinet. Unscrew the two hex bolts at the base of the rear panel that attach it to the base.
Pull the console forward and up a little to dislodge it. Slide it out of the way enough to get access to the two brass clips. Put a flat-head screwdriver in the hole towards the front and pry the clip forward a little to release it. Remove both clips. This releases the rear panel from the top of the cabinet.
One cable goes from the console to the top of the cabinet: this is the lid switch. Disconnect it.
Pull the cabinet forward now that everything is detached. It helps to have someone holding the console and rear panel while you do this. Remove the cabinet.
Place it on something to prevent scuffing, like a few towels or a small animal. The lid switch is the only device here. Unscrew it from the ground (one hex screw) and from the inside of the lid (two Phillips screws). Push the grey tube holding the wires out of the clip holding it in and release the plug from the top of the lid.
Take this to a parts shop and ask for another. It’s around $25-50 depending on how desperate you look.
Snap the gray tube back in, screw in the ground and switch. Close the lid: it should click now. If not, check that you actually screwed the new unit in properly. Yes, the new one.
Replace the cabinet and the rear panel, then the clips and the console. Replace all screws and bolts. Make sure there are no spare parts. Reattach all the cables and hoses and plug power in last.
Test it by putting it on a small load and let some water into the tub. Then stop it, move to spin dry, and start it with the lid open. Nothing should happen. Close the lid (you made sure to replace the drain hose, right?) and it should start spinning and pushing out water.
Congratulations, you saved over $100 and only lost a few hours of your life doing it.
And now you know where my morning went.
Pro tip: don’t let the lid fall down anymore. Place it down, don’t drop it.
Posted on Apr 28, 2009
3 Suggested Answers
SOURCE:
langman_kevi
  • 3 Answers
SOURCE: My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Posted on Feb 29, 2012
ercupa190
  • 12223 Answers
SOURCE: The washer broke filled with water and won't drain
see this causes and fix it. God bless you
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Posted on Sep 29, 2012
Lg intellowasher wd-8015c not draining?
Washer won’t drain, I’ve no blockage but water stays in washer and it won’t spin or drain. Can you help me
Aug 01, 2013 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
Sep 28, 2012 | Kenmore Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer wont drain
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 19, 2009 | Tecnik TKL9260 Front Load Washer
Wirlpool Duel Washer
Could be limescale in the pipes under the sink or blockage in the sink.
Disconnect pump from taps - put bucket under pipe and run tap - if water coughs from that pipe, its the sink not the pump.
Jul 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet f/l loader. The washer fills with water when not on
I FOUND THE PROBLEM WAS THE VALVEWHICH CONTROLS THE WATER INTAKE ON THE TOP OF THE WASHER. I PICKED UP THE REPLACE VALVE IT WAS LOCATED AT THE TOP OF THE WASHER WHERE THE WATER INTAKES ARE. THIS SOLVED MY PROBLEM.
yOUR SITE WAS VERY HELPFULL
THANKS ****
Nov 26, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
409 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
