Question about GE JVM1440 Microwave Oven
Microwave where is the magnetron located
  • yellowboots Mar 20, 2008
    waiting for response
  • GE Master
  • 9,086 Answers
In most models, it is located outside the right side of the cooking cavity.
What problem are you having?
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you have a GE, there should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
I have a G.E. microwave that is 2 years old that won't heat up
most likely there is a problem with the magnetron or the thermal device connected to the magnetron...this is located behind the control panel ... if all the functions are working except heat most likely the magnetron has failed.... good luck to you
Jan 13, 2011 | GE JES735WJ Microwave Oven
Microwave will not heat food but everything else works.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Nov 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My ge microwave spacemaker 1800 won't heat my food pls help
(((The fuse is located inside the unit along side the magnetron, near the blower housing.)))
Nov 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave powers up but does not cook??
Sep 28, 2009 | Viking DMOR205SS Microwave Oven
Microwave Spacesaver #JUM 2050BH001not heating
(((The fuse is located inside the unit along side the magnetron)))...
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not heat but every thing works
Aug 03, 2009 | Kenmore 63252 Microwave Oven
Microwave want heat any longer. Everthing else is
Jul 31, 2009 | Microwave Ovens
Microwave is not heating but light and timer and turning motor are still working fine.
Jul 30, 2009 | GE JES738 Microwave Oven
MICROWAVE NOT HEATING ANYTHING?
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Dec 29, 2008 | Frigidaire FMV145K Microwave Oven
Microwave runs but does not blow heat
(((The fuse is located inside the unit along side the magnetron)))....
Oct 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
