Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt965 1600rpm severe vibration underload and spinning. OK empty. Drum seems very free when moved manually.
Thanks Faggly but it was not the answer!
Resonance is affected by spring stiffness, mass and damping. In this case it was mass. The weight under the drum was loose! My neighbour (always one never to be defeated by a problem) found it by chance when he felt under the drum. Three bolts were all loose. Hopefully it is bad assembly and will not come back.
Thanks anyway
Posted on Mar 22, 2008
    Scholar:
  • 74 Answers
Firstly try making sure that all the feet are tight to the floor, and that it is failrly even... also that it is free of any impedement to the sides of the appliance ..this should sort it .. let me know if it does please!
regards Faggly
Posted on Mar 20, 2008
SOURCE:
Auto washing machine drum vibrates makes loud noise
When machine is empty use fingers to try and move drum side to side. Is there excessive movement? 2 to 3 mm is ok. If drum moves to much it will be the drum bearings. Easy fix for an engineer or competent diyer. Millions of how to videos on utube.
Oct 04, 2015 | Whirlpool Washing Machines
Hotpoint BWD129 Spinning Difficulties
IF it sits and you can turn it later, the only thing that would cause that is something heating up and becoming seized. When it cools off it frees itself. I would check the bearings on the drum.
Mar 12, 2014 | Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
What would the cost be to tighten drum in washer
Sounds like the concrete weight is broken. It stabilises the unit while spinning.If the drum moves inside the tub, the bearing has collapsed
May 09, 2012 | Whirlpool duet Washing Machines
I have got a Hotpoint Aquarius + WF740 1400 spin speed. When the drum is moving slow inbetween cycles there is a wereing noise, In the wash cycle it clunks but it's ok in spin mode. When I move the drum...
there could be something stuck between the inner and outer drum, eg. a bra wire a common culprit.
inside the drum you have 3 lifters ( blue pillars). remove one of these by pulling it towards you.this will allow you to see into the inner drum. get a flash lamp and have a good look rotating the inner drum around.
if you see anything get a pair of pliers to pull in out as you cant get a nasty cut.
replace lifter as u removed it.
if bearings were gone would sound like a tractor while spinning.
Mar 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Wd63 door
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Nov 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
210 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
