Hi,under normal circumstances,the crown ought to rotate both clockwise and anti-clockwise,and the stem ought to pull out after turning anticlockwise.However,if the stem fails to unlock after turning anti-clockwise,i will suggest you take it to the jeweller who sold it to you to help you fix this problem,because the carrera titanium watch is a very delicate and expensive wrist watch to be foddled around with.
Thanks and good luck
Hi
The mechanism of your watch is designed the way that it only rotates counterclockwise.However the stem should be pulled out, it could just be stuck but in order to adjust the time, you should pull it out.If you want to, you may bring the catch to a watch repair specialist and have the stem cleaned to that if you need to set the time, it will be easy to adjust it.
Be careful not to use anything sharp like a blade, you may risk remove the stem handle.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
"clean the stem" on a brand new watch is dumb.
