Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Colors all over
Hi I just recently replaced the convergence ic's in my big screen. Everything went ok but when I turn the tv on all the colors are distinctivly separated.Tried manual and auto positioning ,but certain colors and positions will not adjust.Could I possibly hooked something to the wrong lead or can I set these a different way? Regards Tim
  • Panasonic Master
  • 8,617 Answers
Did you check to make sure none of the IC pins are bridged with solder? Also did you check the resistors that power the ICs in this model usually 1 or 2 of those resistors will go open with the ICs.
Posted on Mar 20, 2008
On the screen there is a green shadow on one side and a red shadow on the other side of every object in the scene
This tv has two big black ICs as convergence output on deflection circuit board that are defective and causing problem in tv, IC number is STK392-110
replace both ICs to solve tv problem, also chekc for faded color big resistor nearby these ICs or those got burn mark, replace these resistors with same value, aslo check cold/ dry solder joints in deflection circuit board and resolder these joint/ connections.
Thanks.
Jan 21, 2011 | Hitachi 65TWX20B 65" Rear Projection...
Television has double images like 3D, and bottom half of screen has a concaved image.
Please replace convergence ICs in tv, there are two big black ICs that has number STK392-110 mounted with big aluminum heat sink, replacement these ICs will solve your tv problem. Also check big resistor nearby these convergence ICs and replace if found burn mark or color faded.
On circuit board, IC location number is IC7001 and IC7002
Let me know if you have additional question.
Thanks.
Dec 25, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi big screen rear projection tv the blue
The tv 100% have convergence problems,it dead.If any colors lines don't matches or stay in the - + convergence grid.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv conververgence board must have these parts changes to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Mitsubishi Televison & Video
Turned on my RCA P46924 today and played fine for 5 min. then picture curved and turned to 3 different colors seperated on same screen. Turned TV off and now will not turn back on. Please help?
Ur tv have convergence problems,before ur convengence ICS totally went dead.U must have tools like soldering iron,solders,solder witch,and know how to solders to fix this problems ur self.Must replaced 2 convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | RCA P46924 46" Rear Projection Television
Tv turns on but the screen is black. Before it went black we were haveing bands of color on the top and bottom and everthing was kind of like in three D they were all three colors and like 3 of them there.
Ur tv have convergence problems,now the 2 STK convergence ICS are completely dead,U lucky u tell it was 3D screen,before it go completely dead,went black screen.Or ur problems it will very hard to diagnose.U now how to do soldering?Must replaced 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 03, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Philips 50p8341a - the red converges, the blue does no move. the screen is all reddish with orange lines in it. the sound is ok. took the back off and the red and blue big lights are on, but the other big...
Hi, convergence IC`s have failed, set is usually a good one, call your local tv shops and get a price to replace the "convergence IC`s ", good luck, video-tek
Jul 01, 2009 | Philips 50P8341 50" Rear Projection...
50h72 replaces ic's but still don't work
Did you replace the convergence resistors along with the Ics? Also if you replaced the ics with open resistors you have most likely ruined the new ICs. You can get a convergence repair kit for your model at the following link which has the ICs and the resistors for your model, and they provide free tech support and instructions.
Heres the link.
http://servicemanuals.vstore.ca/
Oct 25, 2008 | Toshiba 50H72 50" Rear Projection...
JVC big screen t.v.
convergence fail. replace convergence ICs with stk-392-110 can be accessed through the front. take off the speaker grill and panel behind that. there will be a large heat-sink under the picture tubes that is the convergence power board. disconnect all cables(mark any that look the same) going to and from that board de-solder the amps --- replace any burnt or open resistors--- plug everything back in turn the tv on and adjust any alignment needed in the regular tv menu.
Feb 20, 2008 | Televison & Video
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Sony HDTV Convergence Issue
No, You will not solve the problem with only changing the convergence IC, associated resisters may also be required.
Beside of that, after spending time to get parts and replace the ICs, you need to make and adjustment the color lines (about 14 lines)
This adjustment without experience will take you about 3 to 4 times and 4 hours each to get thing right (if you areskillfull, most of people failed this adjustment).. The total time spend for this problem would take you full 24 working hours.
I successfully adjusted one set of my big TV (95%, need more more round)), on another set one I failed.
Nov 30, 2007 | Televison & Video
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
