Question about HP LaserJet 4350 Printer
HP 4350 downgraded to a HP 4250
I had a 57 error on a HP 4350, so we changed the Fans and that worked for a few weeks. Then the error came back and we changed the DC controller, not knowing that there is a procedure that must be followed to the T., which I had no knowledge of. Now that it's working, the configuration page is saying that I have a HP 4250. I tried to now follow the instructions, to get back the printer to remember it's a HP 4350, but alas NO WAY, it still want to stay a HP 4250.
It probably wrote to the formatter already. The only way to get it back to 4350 is to replace the DC controller and formatter from a matched 4350. Otherwise, the formatter will change the new DC controller to a 4250 and you have the problem all over again.
Posted on Nov 23, 2011
    Problem Solver:
  • 10 Answers
This has happened to me a few times. They sent you a refurbished DC Controller that is from a 4250, not a 4350.
What you have to do is get a dc controller for a 4350, and install it so that it rewrites itself as a 4350.
Remember that when you install a DC controller you have to leave printer on for 5 min... then turn off for 5min... (once more, same sequence) and you should be allset.
Posted on Mar 11, 2009
  • 22 Answers
Is this affecting performance? Try new firmware. www.hp.com/go/lj4350_software.
Posted on Jul 06, 2008
My Lexmark 4350 wont recognise a new colour cartridge why?
Please make sure the back plate is clean inside your printer. That the place where to contact points sits. Check the back of the cartridge aswell to insure all contacts are clean. If it still comes up with the error change the cartridge otherwise its a board or caridge wich you cant get new spares for.
Mar 15, 2012 | Lexmark P4350 All-In-One InkJet Printer
51.10 error
Thank you for contacting FixYa. I have been working on some archieved inquiries that may have gone unanswered. Your issue is a beam detect error with your laser scanner.
HP LASER PRINTERS 4200, 4300, 4250, 4350 ERROR 51.XX
1. Printer has a beam detect error
2. Replace the cable ***'y from scanner to D.C. controller
3. Replace the scanner ***'y
4. Replace the D.C. controller.
Aug 25, 2011 | HP LaserJet 4350 Printer
My printer hp laserjet 4350 shows error 49,what could be the cause
Most times a "49" error indicares the need for a firmware upgrade.
If the machine is networked, disconnect the network cable and power the printer off, wait 2 minutes and power it back up. It should reset the error.
BEFORE reattaching the network cable delete the job in the printer queue that caused the error ( Most likely a PDF file).
Go here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=412171&prodTypeId=18972&prodSeriesId=412160&swLang=8&taskId=135&swEnvOID=228#290
and download and install the latest firmware
A workaround is to print the PDF as an image
May 20, 2011 | HP LaserJet 4350 Printer
LaserJet 4350 Printer: 49.2f02 service error on hp 4100 printer...
Turn the printer off for a few minutes and then back on. If that does not fix the problem, try to have the print queue cleared and tray again. Most of the time it's a PDF file that causes this problem. If that does not fix it, it may need a new Jetdirect card.
May 16, 2010 | HP LaserJet 4350 Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
Your fuser element is faulty. Check both connectors, make sure they are nice and secure on the element. Still not working replace element.
Feb 12, 2008 | HP LaserJet 4350 Printer
HP 4350 printer
you might need to upgrade the firmware
Dec 28, 2007 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
369 people viewed this question
Seeker5211
Seeker5211
