Two inch shadow on tv
I have a 56" samsung dlp tv, when I turn it on tonight it now has a shadow on the right side of the tv, about 2" wide all the way down the side. Called samsung and they told me I needed to have a repair tech come out and look. Any hints as to what may be wrong? The tv is only 1.5 years old.
    President:
  • 1,779 Answers
Change the input to AV1 or AV2 with no signal and see if it's still there, if it is you might have a defective light engine in which a lot of manufacturers will warranty. This can be repaired in the home but some shops preferr to take them in, try for the in home co's first. Just a word to the wise, DLP's do not last as long as you may want.
Posted on Mar 20, 2008
There has been a gray shadom on left side of screen, maybe 3 inches wide, for the entire length of the screen. I can see through the shadow, but it is noticeable.... any thoughts?
This tv have a colors wheel design in it.Flashes or discolors on this shadow?Tv making any humming sound or motor noises.Yes,mean the tv colors wheel is dying and spinning out of it motor axis.The color wheel,is the problems.Colors wheel sit way back of the tv,must take out alot of mechanical parts to get to it to replaced.U have no mechanical skills,don't tries this.Hire a tv tech to replace the colors wheel.
Jan 17, 2011 | Samsung DLP HL-P5663W 56" TV
Shadow appeared on my DLP TV after replacing the lamp
this is a light tunnel failure this component will have to be replaced and is a part of the light engine
Feb 14, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
3 problems 1. TV shuts off and on automatically. 2. 2 inch band on left side of screen 3. No picture at all
The band or shadow on the left side of the screen definitely sounds like a defective light tunnel.As for the intermittent pix and shut down this could be the lamp if you have not already changed it.
Oct 15, 2009 | Samsung DLP HL-P5663W 56" TV
I have a 56" DLP Samsung (HLR5668W) Right side goes solid black
The color wheels will never fix an issue like that. The only things that will cause that issue is a bad DMD board which is part of the light engine or the digital board which is not. Freak Squad need to replace the digital board.
Sep 10, 2009 | Samsung HL-R5668W 56" HDTV
We have 2 problems....dark screen/bright light on right side
Replace the light engine. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 11, 2017 | Samsung HL-S5087W DLP TV
Dark shadow about 4'' at top of screen of 56'' dlp samsung hlr5667
There is a piece connected to the color wheel assembly called a light tunnel. It is between the color wheel and optic assembly. There is 4 mirrors inside. One of them probably got dislodged when the wheel shattered. Sometimes they can be repaired using high temp glue or you may have to replace the tunnel.
May 18, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung dlp tv
Yes, it could. There is a light pipe in the light path that could now be broken from the bumping or it could just be out of line from the bumping. Another problem could be the mirrors in the projection path could just need adjusted by the 3 screws that are beside the mirrors. This may also happen when bumped.
Mar 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Shadow down right side of screen on a toshiba 44NHM84 44" DLP television
shadows at the bottom of the screen sound like moisture that was "wicked up" between the screen layers and dryed out leaving a stain. DO NOT get these screens wet, use nothing but a damp soft cloth; just a few drops of water running down the screen can cause a fairly large stain. Some people have suggested that they may be professionally cleaned, but the risk of damage is too great on the user level.
Nov 12, 2006 | Toshiba 44NHM84 44" TV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
