Back to:
Tags:
Edirol UA-4FX External Sound System
Code 12 error
posted by LmofoJ on Mar 19, 2008
I have no sound and i checked my device manager and it says a code 12 error for my midi file.Please help me fix it!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 23, 2008
Not Rated (0)
faheemsafdar
Rank:Guru Guru
Rating: 86%, 88 votes
Enter in your bios setting by pressing DEL, F10, or F2 or as bios setup instructs when u power up your Pc. Just select Default or failsafe setting there, save your setting and exit.Pc will restart and all goes well
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on code 12 error:
I don't want to Accept this solution
Solution #2
posted on Mar 20, 2008
Not Rated (0)
lenny297
Rank:Wiz Wiz
Rating: 85%, 91 votes
Its normally a conflict error where devices are allocated the same IRQ, it's important that u understand how to go about it, the consequences can cause more conflicts if done wrongly, so i suggest u read from this site b4 u change anything
http://support.microsoft.com/kb/310123
Thank You!
Can you Help with these Sound Cards problems?
I have a new vista program and my Edirol is not reading...
I'm wanting to play beeps and tones from my computer over...
Hello Sandrew i have a problem in my laptop (IBM intel...
I have my ua4fx plugged by usb into my laptop and then...
Hi - I have re-hooked my system up. Problem is that the...
Loading problems.
Repair Service
Find Sound Card Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
