Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool super capcity 465 electric range
How do you change the light bulb?
    President:
  • 1,314 Answers
There should be a little wire over the glass cover flip it down and unscrew the bulb like any other bulb
Posted on Mar 19, 2008
6ya staff
SOURCE:
I have a Whirlpool Super Capcity 465 Elec.Range, the oven is way too hot, burning everthing.
Hello Denise,
Very likely the reason it overheats so much is a defective oven temperature sensor, the oven temp. sensor is located in the oven cavity and it should be checked to see if it is within range.
This is what the sensor looks like oldtech2332_152.jpgTo check it,it should be disconnected from the wiring and using a meter set to measure ohms of resistiance and check the sensor at room temp when oven has been off to be between 1060-1100 ohms. If that ohms value is way off the sensor indeed is bad and should be replaced,if at room temp it is 1060-1100 ohms the sensor is ok and the problem lies within the control board.
GENE
Nov 01, 2011 | Whirlpool GS460 Gas Kitchen Range
I am not sure how to use the self cleaning option on my Whirlpool super capcity 465
when you set the self clean from the clock you will find the time and lock up is automatic . when it done and cooled you can get back into the oven . just wipe it out with a damp cloth and done .. mm setting the clock is just a push of the buttom ( touch pad .) mm
Jul 14, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
Jan 20, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
How do I change the oven light bulb on my Whirlpool Super Capacity 465 Gas Stove. There is a cover over the bulb that won't budge what do I do?
ok its been a long time since ive seen this model
but if i remember correctly, that cover pulls out, it does not screw out, sometimes it can be loosened a bit by warming the oven to about 100 degrees, this will swell the metal ring that is the clip for the bulb cover
Oct 17, 2009 | Whirlpool GR460 Electric Kitchen Range
How do I remove the light bulb from the oven of my super capacity 465? The base is the only part of the light remaining. Glass is broken.
this may or may not workk but it has for me many times in the past
trim a potatoe to be a little bigger than the bulb
jam it in the socket, it should be able to turn the base of the bulb out for you
please unplug the range first
Oct 09, 2009 | Whirlpool GS460 Gas Kitchen Range
Heating elements
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Feb 01, 2009 | Whirlpool GR460 Electric Kitchen Range
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Problem with electric range
Most likely the switch has welded closed
Sep 28, 2007 | Kitchen Ranges
Whirlpool Calypso GVW9959K Top Load Washer Logo
128 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
