FixYa.com
Tags:
Ricoh Aficio 1013F Copier
Saying load paper
posted by bre27 on Mar 19, 2008
There is a little black piece under the machine when you remove the paper tray that must register when there is paper in the tray or something, ours has fallen out and has had to be sticky taped to hold it in and print anything or copy anything.
Is there any service people in the Newcastle NSW area that would be able to fix this?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 20, 2008
FixYa! (100)
drichards
Rank:Guru Guru
Rating: 87%, 60 votes
Actually, you probably do not need a service person.
1. Turn machine off.
2. Remove toner assembly, not just bottle.
3. Unplug wire, and remove PCU. (right door must be open)
4. Remove the paper tray.
5 Turn the machine on its side.
You will be able to see, that it just snaps into place. Most likely one of the tabs broke off, but you can put a drop of super glue on it, and it will be fine. Make sure it has free up/down movement when installed before you glue it.
Then, make sure your guides in your paper tray are in there tracks. That is the most probable cause of your problem.
Rating Locked! (?) bre27 has rated this solution as FixYa!
Can you Help with these Copiers problems?
Copiers
minolta
minolta ep 1030 copier paper... Answer This...
Copiers
cf323
same probelem Answer This...
Copiers
Nuvera 100 CP
I have a Xerox Nuvera 100 that... Answer This...
Copiers
toner drum chip reset for xerox...
Sir, I am Ekambaram from India.... Answer This...
Konica 1216 copier makes black...
I bought a preowned copier... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
