Question about Acer Aspire 5100 Notebook
Click pad Acer Aspire5100-3825 Problem: depressed left click pad
  • 3,267 Answers
Its probably stuck. First try cleaning it with pure Ethyl Alcohol and use a blower. If it does not solve the problem, enter your keypad configuration and disable that particular keystroke. After that I am sure you can continue to use the same without any further problems....sodeep
Posted on Mar 19, 2009
    Genius:
  • 1,142 Answers
Plz contact acer support to get the same replaced
Posted on Mar 20, 2008
SOURCE:
Mark favorites delete internet
Left hand mouse = tap the bottom left of pad. Right hand mouse - tap bottom right of pad.
Nov 04, 2013 | Acer Aspire One PC Notebook
Laptop screen frozen;arrow wont move;cant type in user name.ACER Aspire
The appeal to any laptop is the ease of portability of the machine, and an Acer laptop is no different. With an integrated mouse pad, these computers can be quite the boon to those looking to have their technology on the go, but a number of issues can afflict Acer laptops, including unresponsive mouse pads. Fortunately, a few clicks of the keyboard and some driver downloads can alleviate most Acer mouse pad problems.
Take a close look at the Acer laptop mouse buttons. Make sure the exterior of the buttons are clean and that there is no grime around the edges and crevasses of the Acer buttons. Dirt on top of the mouse pad can result in slower performance or an unresponsive experience, while grime around the sides of the mouse buttons can cause problems with the pressing and depressing of the mouse. Is there any way your mouse pad has been turned off? Check into this possibility. On an Acer laptop, hitting the "Function" (Fn) key and "F7" on the key board will result in the mouse pad being switched off. Hence, you may have hit this function and your mouse pad may not actually be broken or require any repair. Hitting the "Fn" button and the "F8" key on the Acer keyboard will result in the mouse pad being turned back on again. Click on the "Printers and Other Hardware" option on your PC. This is an alternative method to the above. At this point, examine the menu that comes up and click on the button at the top that reads "Device Settings." You should then see an option to click on your Acer mousepad. Highlight this option and click "OK." Launch your Web browser and go to the official Acer website. http://www.acerpanam.com/ The above steps may not have worked, so downloading new drivers for your mouse may be necessary. Select your country of origin, then click on "Support." You will be asked to click on your country again. After you do so, click on the link that says "Drivers and Downloads" on the left sidebar. Select your product line ("Notebooks") as well as your specific Acer computer model, and then hit "Search." Click on the link that says "Touchpad drivers." Your Acer computer may only require new drivers for your mousepad. Download the .exe file and run it to install the contents to your Acer computer. Restart your Acer computer after fully completing the download and installation process. Once the restart process has completed, the driver installation will be complete and your mouse should work again.
b>
Feb 06, 2013 | Acer Aspire Computers & Internet
Scroll not working on aspire 5720z
Instructions
Launch your Web browser and go to the official Acer website. The above steps may not have worked, so downloading new drivers for your mouse may be necessary.
5
6
7
Jan 10, 2013 | Acer Aspire Computers & Internet
I HAVE BLOCKED MY CURSOR ON ACER LAPTOP BY MISTAKE
When your mouse pad is not functioning, it's hard to get most anything done on your computer. The fortunate side to all this is that getting a mouse pad to work again on a laptop is not an overly complex procedure. A few troubleshooting techniques will quickly lead you on your way to productivity again.
Examine your mouse pad. Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether. Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component. Check to see if your mouse pad has been turned off. If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad. To enable your mouse pad on a Windows PC go to the Control Menu. Under the Printers and Other Hardware option, click on Mouse. Then, click on the tab on the top of the pop-up menu that says Device Settings. The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work, proceed to the next Step . Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area. Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input. It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad). Then, click on download. Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again. Hope this helps.
Jan 08, 2013 | Acer Computers & Internet
CURSOR IS BLOCKED
Jan 08, 2013 | LG X-Note LM50 Notebook
How to right click on an acer laptop
hi..
you have two buttons near the touch pad. left one for left clich and right side one for right click
if my answer was useful please vote me
Jul 14, 2010 | Acer Aspire 5610-4648 Notebook
Acer 5517 mouse pad does not work. is it just a
First you should check if the button that enables and disables your touch pad is on. It's the button left to the power button.
Feb 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5536 its touchpad seems to be broken no left click but can right click and scoll
if theirs no left click wen you tap the touch pad you have to enable that from pointer options if theirs no left click from the left click buton you need to take it to waranti
Jan 04, 2010 | Acer Aspire 5536-5224 Notebook
Broken Button
Hello Roinette,
It is unfortunate to know about that. However as you told that the left click button of the touch pad for you acer laptop has broken or damged, the only way to get it resolved is to get the laptop serviced. As the laptop touch pad and keypad is integrated directly with the mother board it is not possible to fix just that paricular button. The pad must be replaced. Get in touch with the acer technical support , they will replace the pad for you.
Thank you. Best of Luck.
Oct 20, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 5100 Notebook Logo
48 people viewed this question
Ekse
Alun Cox
