Question about Nu Mark Numark Axis9 Table Top CD Player CD Player
I have a 'Numark Axis 9' DJ standard CD player. While it knows there's a disc in the unit it does not read it. Tried many discs, none get read. Any ideas?
    New Friend:
  • 17 Answers
You will most likely need to replace the CD drive. I believe the OEM part is CM-H90. Only 8 screws to complete this task.
Posted on May 05, 2010
SOURCE:
NUMARK MP102 - When we put in an audio CD the CD sounds like it is spinning but the display says "NO DISC". Thank you in advance for your time.
it could be bunch of ting 1clean lens with soft cloth 2 it could be wrong disc,check n see if it as digital audio compatibility cd or it the unit just not reading the disc i think it is the wrong disc
Aug 03, 2011 | Numark MP-102 CD Player
Alright well I have a Numark rack mount dj set with two CDN95 2 disc players. Well I bought it used with speakers and everything and do not know how to plug everything, I really need some help please...
As shown in the Quick Start Guide (link below) this unit should be connected to a Mixer Unit.
http://www.numark.com/stuff/contentmgr/files/0/662529d8e9e5b8ebe1747274e5bad9d6/file/cdn95_quickstartguide.pdf
Looking at the Diagram they appear to be standard AV Cables so you should just be able to plug the CD Outputs into the Amp AV Inputs (as long as it's a Dual Amp) and then connect your speakers to the Amp (make sure the speakers impedance matches the Amp.
Further details available at http://www.numark.com/cdn95?tt=5
Please leave feedback
Cheers
Andy
Apr 25, 2011 | Numark CDN95 2-Disc CD Player
Want to connect my nu mark axis 9 to my computer by using virtual dj
Hi gregory_fils,
Please read the manual which came with your nu mark axis 9 to see if it is compatible with your computer if so, there should be instructions in the manual.
i hope this helps.
Mar 27, 2011 | Nu Mark Numark Axis9 Table Top CD Player...
I have the Numark CD Dj in A Box NDX200 and I'm getting a No
Did you try multiple discs? I would say the CD drive is defective. You should still be covered under warranty. Contact Numark for service repair.
Dec 25, 2009 | Numark CDX Turntable
My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Jan 05, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Problem with numark cdn 88 disk loads but does not read
my best suggestion, if it won,t read any discs then it need repairing. go through your newmark retailer .they can normally get it fixed by numark. newmark players do go this way unfortunately. if it happens again ,don't buy cheaper models in future. i have had numreous problems with numark axis 9 cd players and in the end i replaced them with a different make.
Nov 10, 2008 | Audio Players & Recorders
Parts for numark axis 9
Numark address in the UK is: NUMARK UK LTD UNIT 9, THE CHRISTY ESTATE IVY ROAD ALDERSHOT GU124TX UNITED KINGDOM Tel: +44 1252 341 400 I would give them a call. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 31, 2007 | Nu Mark AXIS 9
Cd players locks up when power switched on
arg... email numark they will give you a uk brach to email - there is a reset facilty that may help you (sorry cant rememeber the buttons it was yonks ago) while it sorted mine 'scratch' is now permanently lit only... they suggested a servide to clear that one prob but got used to cueing the record on that deck in scratch mood which is an art in itself lol
Sep 18, 2006 | Nu Mark AXIS 9
Open Questions:
Numark Axis-9s and problems playing burned discs (summary of all problems / any solutions?) These Numark Axis-9s were quirky straight out of the box, but anyone that owned these cd turntables grew fond of them. A lot of people that use the Numark Axis-9s have problems that occur when using burned discs. Problems such as: Pops and noise in the track Skips in the track A sudden looping of the track (usually 1 to 3 seconds) Inability to read the disc, the buttons would lock Many problems with the scratching features Many advanced feature problems, etc Here's what we know: 1) Although this puts a huge negative on the Numark Axis-9s, the players DO read burned discs perfectly. 2) The problem is either the computer burning the discs, the program burning the discs, the settings of the burn, or the actual discs. Sidenote: Has the quality of blank discs changed over the past 5`-10 years? Perhaps not a "poorer" quality, but have discs become "more digital" making the Axis9s unable to read newer blanks? I have used 6 different Axis-9s over the course of about 6-7 years. Here's what I know: My old-old computer (2 computers ago, 6 years ago) used to burn discs and the players would play without a problem. My old computer caused burned discs to have various problems in the players. Not many though, not as many as now. Then, I used iTunes to burn, and burned at the slowest speed, and usually got a good disc burn. My current computer, every burned disc does not work. I have tried various burning speeds and have found that 8x is currently the best, although I still cannot get a solid quality burned disc. Some tracks work. Most don't. Sidenote: If the BPM shows up on a track, it will play properly. If there's any delays in the displays showing up, such as the timelength of the track, the track won't play properly. Is anyone currently burning discs that the Numark Axis-9 players are playing? If so, what is your method? Are there any other Axis-9 users that have tips burning a disc that plays correctly?
Feb 27, 2017 | Nu Mark Numark Axis9 Table Top CD Player...
Nu Mark Numark Axis9 Table Top CD Player CD Player Logo
255 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
da surgen
Morne Olivier
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
