Question about Texas Instruments TI-85 Calculator
DIM SCREEN!!!!!!!! I cant see my screen, it is dim and i can barley read it, got a test tomorow, WHAT CAN I DO!
  • 1 more comment
  • Anonymous Mar 28, 2008
    just changed batteries and now my screen is to dark to see anything on.
  • msb44nc Nov 17, 2008
    I put in new batteries, but the screen is dim, very hard to read. Help. I used copper top batteries. does this make a difference?
  • sharonnie Jan 17, 2009
    I had the same problem. I did what Medinajaviersuggested (pressing the 2nd key, then pressing the up key, then pressing the 2nd key again and the down key), and it worked perfectly!! I thought I was going to have to buy another calculator!!
    Thank you soo much Medinajavier!!!!!!!!!!!!!!!
Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
Posted on Jan 13, 2009
  • 3,037 Answers
Press 2nd and then hold arrow up and it should work otherwise you may need new batteries, let me know if this doesn't work and I will try to figure out a different solution
Posted on Mar 22, 2008
SOURCE:
Monitor is very dim
Just go to windows button search for battery then
you will see like this and check your screen brightness is it full
Dec 04, 2013 | Computers & Internet
My screen is very dim
boot to the BIOS (F2 at boot) and ensure that the LCD brightness is set to 8 and then reboot, if LCD is still dim, then, check the Control point system manager display settings and see if the LCD is dimmed there.
If no change, run diags Power + D at boot to run the LCD BIST test , if the 4 colored screens are DIM during the test, then the LCD has failed and needs repplacement.
Jun 29, 2011 | Dell Latitude E6500 Laptop
Can not read the screen--too dim
cant, its either the lcd itself or the lcd power inverter.
Mar 23, 2010 | Motorola Mobility MA351 Cordless Phone
How do I adjust brightness on my acer 5570Z
Use the special function keys to adjust screen and speakers:
<Fn> + <→> = brighter
<Fn> + <←> = dimmer
<Fn> + <↑> = volume up
<Fn> + <↓> = volume down
Jul 10, 2009 | Acer Aspire 5630 Notebook
Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there.  You may have the backlight turned off.  If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed.  Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
May 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
My laptop screen is very dim, cannot read or see looks faded
Try using the brightness controls on your keyboard to brighten the screen. If that doesn't work then that means either the lcd or the inverter has gone bad.
Apr 14, 2009 | Computers & Internet
LCD goes dim within 1-2 minutes
You could have a bad "inverter" or flourescent backlight tube, or a problem in your power supply.The only way to isolate the problem is to check each component in sequence.If your hard disk and DVD / CD drive are still working when your screen goes dark, then I'd say it's the "inverter". You'll have to take it to a repair shop.
flipbooks
Jan 20, 2008 | HP Pavilion dv6000z Notebook
Screen is dim
Try looking for a function key (usually used by holding down the Fn key and then pressing one of the "F" key at the top) the key will be marked with a brightness indicator.
Is your screen only dim when running off the battery is it dim when running when the charger is plugged in as well. If it is only dim when the laptop is running on battery then this may be caused by a setting in Power Options which is located in Control Panel (that is if your running Windows). In Power Options look for settings about running on AC Power and running on Battery power.
Jan 07, 2008 | Dell Inspiron 8500 Notebook
Treo 650 screen brightness
Try Pressing the Option button and then P to bring up the Adjust Brightness control enabling you to dim or brighten the screen.
Dec 29, 2007 | Palm Treo 650 Handheld
Texas Instruments TI-85 Calculator Logo
286 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
