Sharp pc al27
I have a sharp pc al27 laptop. I just tried to install a 1 GB memory stick. Installation was easy but my laptop would not boot with the new memory. Put the old memory back and no problems....what to do. oh what to do??
    Sergeant:
  • 349 Answers
Swap the memory sticks around,this usually works for me.
good luck
Terry
Posted on Mar 20, 2008
  • terry Mar 20, 2008
    you may also need to go in ,then straight out of the bios saving changes
    (though you have made none)
    good luck
I tried to upgrade the memory from 1 GB to 2 GB, but after that the computer's screen won't turn on, and i can hear three long beeps and two short ones
The beeps indicate memory issue.
Acer Aspire One Notebook supports upto 1.5GB of memory, so if you try to install 2GB it will not work.
Size 1.0 GB / 1.5 GB (max)
Technology DDR2 SDRAM - 533.0 MHz
Form Factor SO DIMM 200-pin
You can also Click Here to check the specs on the Cnet website.
Regards,
Shrey
May 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
Installed 2 gb memory, when turning computer on it tell me windows error and won't go any further, it is a blue screen
Have you removed the memory you added and tried to boot.
If you now have 2 memory sticks have you tried each 1 on there own.
Your manual says you can fit 4gb max installed as 2x2gb ddr533 or ddr667.
Sometimes you do get a bad stick of memory
Jul 11, 2010 | Acer Extensa 4620 Notebook
How to upgrade memory. I need module definition for 1Gig so I can purchase it.
You need a 512MB PC2700 DDR 333MHz SO-DIMM for a laptop (200-pin). The manufacturer I think doesn't specifically support anything over 512MB. But the RAM is standard and I doubt there is any need to buy it directly from Sharp. The laptop only has one upgradable bay so you may not be able to upgrade past 1.25 GB.
One of the memory covers is not removable, if I remember correctly, that is the one under the keyboard. So the one you update is a panel on the bottom.
Mar 11, 2010 | Sharp Actius AL27 Notebook
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    Laptop Sharp PC-AL27 Heatsink Cooling Fan\none found
    If it's an older laptop, sometimes you can find a parted out one on e-bay?
    Mar 03, 2009 | Computers & Internet
    Error message after installing memory ram upgrade.....
    The memory appears to be the right kind.
    Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
    Dec 20, 2008 | Dell Inspiron E1505 Notebook
    ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
    YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
    Sep 16, 2008 | Computers & Internet
    Wireless adapter
    navigate to device manager. look for the unknown device with an exclaimation mark on it. right mouse click and update the drivers..navigate to your cd room where the driver resides and install it manually.
    Jan 22, 2008 | Sharp Actius AL27 Notebook
    Computers & Internet Logo
    48 people viewed this question
    Alun Cox
    David Payne
    David Payne
