HP monitor problems
I have a HP desktop monitor that is about 4 years old. It has worked fine but all of a sudden it doesn't work. When I power up the computer, the green light indicator comes on like normal but them it switches to the orange light and the screen stays black. I have disconnected it from the computer and the screen says "no signal". Is there anything I can do?
    Scholar:
  • 178 Answers
Look into trying a PCI video card. I doubt the monitor went bad, however, the onboard video controller for the PC may have.
Posted on Mar 20, 2008
Desktop all of sudden don't display
Please follow the steps below
1. Please check the video port connection if properly plug-in it could be loosen
2. Please check if the power cord of the monitor is properly plug-in maybe it was accidentally disconnected from the power source.
3. Press the power button on the monitor ad check all the LED lights.
4. To isolate the issue we can use other monitor or we can try the monitor that is not working to other PC.Again,if the problem continues plase call the manufacturer or call the store where the item was purchase.
Sep 04, 2011 | HP Compaq dc7600 Small Form Factor PC...
I have a Trulink VGA 4 port KVM switch. Has worked fine for a year plus. Just moved it to a new room, and reconnected the same computers to the switch using a new monitor. I can't get the monitor to work....
Maybe the switch doesn't support the type of monitor that you are trying to use. Have you tried switching back to the old monitor to see if that one still works?
May 04, 2011 | Computers & Internet
Have a Pavilion Desktop HP with upgrade from vista to windows 7 ultimate. Turned the power on and no blue light and no monitor yet the fans were running. Computer monitor said no input and went back to...
First I think you should do some troubleshooting. Try hooking up your computer to a different monitor and see if there's any display when you boot up. If that doesn't work, then open up the desktop and make sure all of the power connections are solid. One that sometimes comes off is the 2nd motherboard power connector. Because you aren't seeing the blue LED, I think it might be that connector. The motherboard has one 24 or 26 pin power connector and one simple 4 pin connector. The 4 pin is usually in a corner near the processor. Take a look at that to see if your motherboard is getting all of the power it needs. If everything is connected properly and your monitor isn't the problem, the new power supply you ordered could fix the problem. I hope this helps!
Apr 15, 2011 | HP Pavilion a6750f PC PC Desktop
My HP pavilion has stopped running, no power to tower, just a blinking green light in the back of the tower. Everything else works fine monitor, printer. Do I need another power supply. My computer is 10...
I strongly advise you to replace your old (VERY OLD!!) PC with new one. Do not worry, you will not lose any data from your old PC if you will take hard drive off your old PC and fix to new one. Anyway, if you still want to keep your old PC (NOT RECOMMENDED) you will have to buy new Power Supply and clean up your PC inside.
Oct 24, 2010 | HP Pavilion a706n PC Desktop
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Sudden power shut down/will not power up
Try these steps :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If the Notebook doesnot start fine, we may have to need a Desktop monitor to check whether the issue is with the LCD, Graphic Card or the Motherboard itself.
Connect a Desktop Monitor to the VGA Port of the Notebook and press FN + F4 key to get the display on the Desktop monitor after the power button is pressed.
If you get the display on the Desktop monitor, the issue is with the LCD of the Notebook.
If there is no display either on the LCD or the Desktop monitor connected, the issue can be either with the Graphic Card or with the Motherboard itself.
Confirm if the Notebook is in warranty or not.
There are some known issues with few HP Pavilioin Notebooks installed with AMD Processors.
Try the link below and contact HP Chat Support if the Notebook is purchased in US to get it repaired for free :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01087277&dlc=en
Check the Product Number if it is listed among the once listed in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=c01300427#c01300427_
You can get the Notebook repaired for free if it listed among these numbers and is purchased from US.
Hope this helps...
Aug 13, 2008 | HP Pavilion dv6000z Notebook
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
No power!!!
Dear javier4017,
> First ensure that any beep is coming or not
> check numlock LED status glowing or not.
> If numlock LED glowing it means cpu working fine
only problems with monitor
>If numlock LED not glowing its mean problems with cpu
> if problems with CPU Find check RAM may have dusting problems.
Dec 07, 2007 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
Computers & Internet Logo
90 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
